Home » Archived » Visual Editor (VE) » swingX for VE
swingX for VE [message #120148] Tue, 07 March 2006 11:38 Go to next message
Originally posted by: pierre.couvy.free.fr
--------------050307030604090406000400
Content-Type: text/plain; charset=windows-1252; format=flowed
hi all !
I do some plugins for Eclipse. For now, most of them are a lamer
Re: swingX for VE [message #120171 is a reply to message #120148] Tue, 07 March 2006 12:08 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Sounds great!
If you are working with VE 1.2, I ask that you also create a version
that pre-reqs 1.2 and does the migrations of the palette and the
override files to the new supported format. The migrated files, however,
will not work with VE 1.1. But the new formats will be the ones that
will be supported from VE 1.2 on.
See http://www.eclipse.org/vep/WebContent/docs/migration/migrati on.html
Pico wrote:
> hi all !
> I do some plugins for Eclipse. For now, most of them are a lamer’s job.
> I mean, they just do a “package” for works of other people.
> There is also “Swinglabs for Visual Editor” plugin. It extends the
> palette with swingx components.
> You can have all of that by adding an udpate site. So it's easy to
> install, test, and even to uninstall ;)
> Please just use “Help>Software updates>Find and install…” menu; then
> choose “Search for new features to install” and press “Next” button. In
> the next panel, click the “Import sites…” button and select the joined
> file.
> more info at :
> http://pierrecouvy.free.fr/?page_id=5
> <bookmarks>
> <site name="Pico&apos;s Eclipse Workshop" url="http://pierrecouvy.free.fr/eclipse-zone/updates" web="false" selected="true" local="false"/>
> </bookmarks>
Rich Kulp
Re: swingX for VE [message #120183 is a reply to message #120171] Tue, 07 March 2006 12:33 Go to previous messageGo to next message
I do it for Eclipse 3.1.2 and its VE version. In fact, it's for my
special needs ;) and i think it could interest other guys.
Thanks to your link, i see that this format should be supported by VE
1.2. So i'll do the migration at eclipse 3.2 RC, not before. I mean
3.1.2 is still the regular version to use.
I add the migration to my TODO list ;)
Rich Kulp a écrit :
> Sounds great!
> Pico wrote:
>> hi all !
>> job. I mean, they just do a “package” for works of other people.
>> In the next panel, click the “Import sites…” button and select the
>> joined file.
>> more info at :
>> <?xml version="1.0" encoding="UTF-8"?>
>> <bookmarks>
>> </bookmarks>
Re: swingX for VE [message #120197 is a reply to message #120183] Tue, 07 March 2006 12:58 Go to previous messageGo to next message
Thanks, that's fine. This was just a heads-up to get you to a supported
api when you can.
Rich Kulp
Re: swingX for VE [message #120209 is a reply to message #120197] Tue, 07 March 2006 13:05 Go to previous message
> api when you can.
you are right ;)
Re: swingX for VE [message #612280 is a reply to message #120148] Tue, 07 March 2006 12:08 Go to previous message
Sounds great!
Pico wrote:
> hi all !
> file.
> more info at :
> <bookmarks>
> </bookmarks>
Rich Kulp
Re: swingX for VE [message #612281 is a reply to message #120171] Tue, 07 March 2006 12:33 Go to previous message
Rich Kulp a écrit :
> Sounds great!
> Pico wrote:
>> hi all !
>> joined file.
>> more info at :
>> <bookmarks>
>> </bookmarks>
Re: swingX for VE [message #612282 is a reply to message #120183] Tue, 07 March 2006 12:58 Go to previous message
api when you can.
Rich Kulp
Re: swingX for VE [message #612283 is a reply to message #120197] Tue, 07 March 2006 13:05 Go to previous message
> api when you can.
you are right ;)
Previous Topic:swingX for VE
Next Topic:Create Visual SWT class not directly from Composite but from derived class
Current Time: Sat Nov 08 14:33:12 EST 2025
Powered by FUDForum. Page generated in 0.04539 seconds
