Home » Archived » BIRT » Error in viewer when calling it from RCP but not from eclipse (with Birt 2.0)
| Error in viewer when calling it from RCP but not from eclipse (with Birt 2.0) [message #120086] |
Mon, 30 January 2006 12:12   |
Eclipse User  |
Originally posted by: nicolas._no.spam_legrain.fr
hi,
I 've updated my installation from birt v1.0.1 to v2.0.
At the beginning, I've got an "HTTP internal error 500" when I launch the
preview from eclipse. Then, I restart Eclipse with the -clean option and now
the preview works well from eclipse.
But, I launch my RCP application, if I open the preview (from my application), I
always got this error : internal error 500
HTTP Status 500 -
 > type Exception report
 > message
 > description The server encountered an internal error () that prevented it
 > from fulfilling this request.
I've got the third party jars, I've make the -clean and it works in eclipse but
not in my application. I really don't understand.
The only thing that I haven't done yet is suppressing all the folders of the
v1.0.1 of birt in my eclipse directory. (But if it works in eclipse, ...)
Thanks for your help.
| Re: Error in viewer when calling it from RCP but not from eclipse (with Birt 2.0) [message #120202 is a reply to message #120086] |
Mon, 30 January 2006 15:04    |
Eclipse User  |
The RCP also requires the same additional third-party libraries that BIRT
Report Designer does.
If you've already loaded these, you can also start the RCP Report Designer
using the -clean option. This should solve your problem.
"nm" <nicolas@_no.spam_legrain.fr> wrote in message
news:drlhg5$poc$1@utils.eclipse.org...
> hi,
> now
> application), I
> HTTP Status 500 -
> > message
> > it
> eclipse but not in my application. I really don't understand.
> the v1.0.1 of birt in my eclipse directory. (But if it works in eclipse,
| Re: Error in viewer when calling it from RCP but not from eclipse (with Birt 2.0) [message #120688 is a reply to message #120202] |
Tue, 31 January 2006 03:34    |
Eclipse User  |
Thank you for your answer.
The problem is that I am talking about my own RCP application (which embed birt)
not the "RCP Report Designer". I don't use the "RCP Report Designer".
I've made a simple test .rptdesign with eclipse (not RCP Report Designer).
In eclipse, the preview works but when I call the preview from my RCP
application it fails.
When I run my application from eclipse, I think it use the Birt's plugin from my
eclipse directory with the third-party libraries, no?
If I run the application out of eclipse (after exporting it) I have the problem.
I've also tried to use -clean option when I launch my application.
>> hi,
>> now
>> application), I
>> HTTP Status 500 -
>>> message
>>> it
| Re: Error in viewer when calling it from RCP but not from eclipse (with Birt 2.0) [message #120748 is a reply to message #120688] |
Tue, 31 January 2006 05:14    |
Eclipse User  |
Application server stack trace :
exception
javax.servlet.ServletException: L''exécution de la servlet a lancé une exception
 org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:269)
 org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:193)
 org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:256)
 org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:643)
	at  org.apache.catalina.core.StandardPipeline.invoke(StandardPip eline.java:480)
	at  org.apache.catalina.core.ContainerBase.invoke(ContainerBase. java:995)
 org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
	at  org.apache.catalina.valves.CertificatesValve.invoke(Certific atesValve.java:246)
 org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:641)
	at  org.apache.catalina.core.StandardContext.invoke(StandardCont ext.java:2422)
	at  org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:180)
 org.apache.catalina.valves.ErrorDispatcherValve.invoke(Error DispatcherValve.java:171)
 org.eclipse.tomcat.internal.EclipseErrorReportValve.invoke(E clipseErrorReportValve.java:153)
 org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:174)
	at  org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapte r.java:199)
	at  org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:828)
 org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.processConnection(Http11Protocol.java:700)
	at  org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndp oint.java:584)
 org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:683)
	at java.lang.Thread.run(Thread.java:595)
cause mère
java.lang.LinkageError: Class javax/servlet/ServletContext violates loader
constraints
	at java.lang.ClassLoader.defineClass1(Native Method)
	at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
 org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.d efineClass(DefaultClassLoader.java:370)
 org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClassLoader.java:233)
 org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClassImpl(DefaultClassLoader.java:343)
 org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClass(DefaultClassLoader.java:235)
 org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. findLocalClass(AbstractClassLoader.java:183)
 org.eclipse.core.runtime.adaptor.EclipseClassLoader.basicFin dLocalClass(EclipseClassLoader.java:141)
 org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:68)
 org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
 org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:389)
 org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
 org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
	at  java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
 org.eclipse.birt.core.framework.PlatformServletContext.getFi leList(PlatformServletContext.java:58)
org.eclipse.birt.core.framework.server.ServerPlatform.<init >(ServerPlatform.java:55)
	at  org.eclipse.birt.core.framework.Platform.initialize(Platform .java:85)
	at org.eclipse.birt.report.engine.api.ReportEngine.<init>(ReportEngine.java:80)
 org.eclipse.birt.report.services.ReportEngineService.setEngi neContext(Unknown
Source)
	at  org.eclipse.birt.report.viewer.servlet.ViewerServlet.doGet(U nknown Source)
	at  javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
	at  org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
	at  javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
 org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:247)
> embed birt)
> from my eclipse directory with the third-party libraries, no?
> problem.
>> BIRT Report Designer does.
>> Designer using the -clean option. This should solve your problem.
>>> hi,
>>> the preview from eclipse. Then, I restart Eclipse with the -clean
>>> option and now
>>> application), I
>>> HTTP Status 500 -
>>>> message
>>>> prevented it
>>> of the v1.0.1 of birt in my eclipse directory. (But if it works in
>>> eclipse, ...)
| Re: Error in viewer when calling it from RCP but not from eclipse (with Birt 2.0) [message #121613 is a reply to message #120688] |
Tue, 31 January 2006 10:05    |
Eclipse User  |
I think I've found the origin of my problem.
I don't launch the "birt viewer" webapp well in the embedded tomcat.
But I don't know how to do this.
Here is the code I use :
//This fails (but works with birt 1.0.1)
     WebappManager.start("birt" , "org.eclipse.birt.report.viewer", new
Path("/birt"));
     String url =
"http://"+WebappManager.getHost()+":"+WebappManager.getPort()+ "/birt/";
url+="run?__report=C:/myproject/new_report.rptdesign";
 org.eclipse.birt.report.viewer.browsers.BrowserManager.getIn stance().createBrowser(false).displayURL(url);
If I don't start the webapp myself and I use this code:
	WebViewer.display("C:/myproject/new_report.rptdesign", WebViewer.HTML);
I can view the report (but I've oda problems if i use jdbc).
So I think the method I use to start the viewer webapp isn't good.
What should I do?
> embed birt)
> problem.
>>> hi,
>>> option and now
>>> application), I
>>> HTTP Status 500 -
>>>> message
>>>> prevented it
>>> eclipse, ...)
| Re: Error in viewer when calling it from RCP but not from eclipse (with Birt 2.0) [message #122126 is a reply to message #122021] |
Tue, 31 January 2006 16:49   |
Eclipse User  |
If I launch the webapp with
Path("/birt"));
it doesn't work => http error 500
but if I use
WebappAccessor.start("birt" , "org.eclipse.birt.report.viewer", new
 >> Path("/"));
it works.
Jason Weathersby a écrit :
> One of the things that changed between 1.0.1 and 2.0 is that the viewer
> plugin doesnt have the plugins folder any longer.
> If you are deploying it without all the other BIRT Plugins, you will need to
> create the older style plugins directory beneath the the
> Viewer plugin or just add the required ones directly to the Eclipse/plugins
> folder.
> Jason
> news:drnub3$rm3$1@utils.eclipse.org...
>> Path("/birt"));
>>     String url =
>> WebViewer.display("C:/myproject/new_report.rptdesign", WebViewer.HTML); I
>> What should I do?
>>> embed birt)
>>> Designer).
>>> problem.
>>>>> hi,
>>>>> option and now
>>>>> application), I
>>>>> HTTP Status 500 -
>>>>>> message
>>>>>> it
>>>>> eclipse, ...)
 Current Time: Tue Nov 04 06:09:31 EST 2025
 Powered by  FUDForum. Page generated in 0.04328 seconds
