Home » Eclipse Projects » GEF » Drawing straight edges
Drawing straight edges [message #119160] Mon, 23 February 2004 21:09
Originally posted by: bharath.starthis.com
Hi Devs,
When I draw an edge between my edit parts, the edge does not appear as a
straight line. I looked at the WORKFLOW example and I am able to draw
straight line edges only to one side of my edit part (left or right)
because I do not have input and output ports like the WORKFLOW example.
If I had an edge between two edit parts, is there a simple way to draw the
edge as a straight line?
Thanks!
Bharath.
Previous Topic:refresh the label's content on connection
Next Topic:Different connections for same edit part
Current Time: Fri Nov 21 20:59:43 EST 2025
Powered by FUDForum. Page generated in 0.03000 seconds
