Home » Language IDEs » Java Development Tools (JDT) » exporting a "run configuration"
exporting a "run configuration" [message #118736] Wed, 19 November 2003 16:35 Go to next message
I am developing a complex program with a fairly large classpath (about 40
entries, including jars and directories), a custom launch directory, and
several command line arguments (program and JVM). The eclipse runtime
configuration screen organizes all of these options nicely, but now I need
to run exactly the same program from the command line. Is there a plugin
available that will automatically export a runtime configuration into
command line format? Doing it manually is tedious and error prone.
thanks very much for any help you can give me.
-amin
Re: exporting a "run configuration" [message #119057 is a reply to message #118736] Thu, 20 November 2003 13:43 Go to previous message
There is no explicit support. However, if you launch the config in Eclipse,
you can then select the associated process in the Debug View, and select
"Properties..." from the context menu. This will display the command line
used to lanuch the app, which you can then copy/paste.
Darin
"Amin Ahmad" <amin_ahmad60@hotmail.com> wrote in message
news:bpgnmo$9jk$1@eclipse.org...
> Hello,
> -amin
Previous Topic:Re: Runtime classpath problems
Next Topic:Debugger does not hilite the code in the code browser window
Current Time: Mon Nov 17 20:24:50 EST 2025
Powered by FUDForum. Page generated in 0.03523 seconds
