Home » Newcomers » Newcomers » Eclipse file path problem
Eclipse file path problem [message #118271] Thu, 17 November 2005 06:18 Go to next message
Originally posted by: muppet_tizer.hotmail.com
My class uses a relative path to open a file MyFile.txt
e.g. the package is com.test.myprogram.MyClass
The relative path in my code is ../../../ so it should go back three
folders from the folder com where MyFile.txt is located.
However the problem is that when I run it inside Eclipse it uses the
project file as the location to go back from.
Hope you understand.
Re: Eclipse file path problem [message #118478 is a reply to message #118271] Fri, 18 November 2005 17:09 Go to previous message
Generally it is good practice to use Class.getResource() or
getResourceAsStream() to read files. That way you specify the file
location as relative to the class not a fixed position on the file system.
If you do that you'll have less trouble making it work in different
environments.
HTH,
Eric
Previous Topic:Multiple Perspectives?
Next Topic:.classpath problem?
Current Time: Wed Oct 29 11:35:07 EDT 2025
Powered by FUDForum. Page generated in 0.09640 seconds
