Home » Language IDEs » Java Development Tools (JDT) » accessing project classpath from within ant file
accessing project classpath from within ant file [message #116511] Wed, 12 November 2003 15:22 Go to next message
hi all,
i'd like to compile a whole project using the external javac compiler.
afaik this is only possible by using an ant script.
the project has dependencies on other projects and on some external jars
all defined in 'properties -> java build path' in the ide.
how can i access the java build path from within my ant script ?
thanks
jakob
Re: accessing project classpath from within ant file [message #116519 is a reply to message #116511] Wed, 12 November 2003 15:27 Go to previous messageGo to next message
forgot to mention that i use eclipse 3.0 M4 under win 2k.
Jakob Braeuchi wrote:
> hi all,
> thanks
> jakob
Re: accessing project classpath from within ant file [message #121964 is a reply to message #116519] Tue, 25 November 2003 17:32 Go to previous message
Originally posted by: meshcheryakovsemen.hotmail.com
for plugins you can select - 'Generate build.xml' from the local menu for
plugin.xml
-- Sam
It's better to view source code than comments to it.
Previous Topic:editable partitions
Next Topic:Integrating Hibernate into build process
Current Time: Mon Nov 03 06:50:59 EST 2025
Powered by FUDForum. Page generated in 0.27107 seconds
