Home » Modeling » BPEL Designer » Compile&build BPEL Designer
Compile&build BPEL Designer [message #10472] Tue, 15 April 2008 09:15 Go to next message
Hi to all,
I need to customize the BPEL Designer and I downloaded the source
code..but..how can I do to build and install it? By maven?By ant? Which
are the precise steps?
I would be grateful if you could help me!
Thank you in advance!
Re: Compile&build BPEL Designer [message #10702 is a reply to message #10472] Fri, 13 June 2008 04:56 Go to previous message
Hi - see
http://www.eclipse.org/bpel/install.php
step3 and beyond.
Previous Topic:Documentation for the BPEL Designer
Next Topic:Open, view .bpel file
Current Time: Fri Nov 07 07:26:00 EST 2025
Powered by FUDForum. Page generated in 0.03691 seconds
