Home » Archived » BIRT » Preview Error when we preview using source code
Preview Error when we preview using source code [message #113994] Tue, 24 January 2006 06:51 Go to next message
sir,
We downloaded the source code and compiled successfully when we
execute,it opens another ReportDesignPerspective, there we create report
and when we try to Preview it,we are getting below Error msg.we came to
know from Documentation that BIRT Framework has inbuilt Tomcat server
that gets invoked each time when you preview the report,so we installed
Tomcat5.0 and given its port no and our local machine ip address in the
windows preference -->Birt--->preview server and tried still same error.Is
there is anything we left out or we got into wrong procedure?
Error Message:
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it
from fulfilling this request.
exception :
javax.servlet.ServletException: Error instantiating servlet class
org.eclipse.birt.report.viewer.servlet.ViewerServlet
root cause :
java.lang.NoClassDefFoundError: javax/xml/soap/SOAPException
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:16 10)
at java.lang.Class.getConstructor0(Class.java:1922)
at java.lang.Class.newInstance0(Class.java:278)
at java.lang.Class.newInstance(Class.java:261)
Thankyou
jegadeeswari
Re: Preview Error when we preview using source code [message #114050 is a reply to message #113994] Tue, 24 January 2006 07:28 Go to previous message
Originally posted by: jan.tanis.coas.com
I think your missing some libraries from axis. Try to add those.
Regards, Jan.
jegadeeswari wrote:
> sir,
> report and when we try to Preview it,we are getting below Error msg.we
> came to know from Documentation that BIRT Framework has inbuilt Tomcat
> server that gets invoked each time when you preview the report,so we
> installed Tomcat5.0 and given its port no and our local machine ip
> address in the windows preference -->Birt--->preview server and tried
> still same error.Is there is anything we left out or we got into wrong
> procedure?
> Error Message:
> HTTP Status 500 -
> message
> it from fulfilling this request.
> exception :
> root cause :
> Thankyou
> jegadeeswari
Previous Topic:How to specify default value for date in birt
Next Topic:API Documentation
Current Time: Sun Nov 30 05:42:24 EST 2025
Powered by FUDForum. Page generated in 0.03858 seconds
