| Non Integrated AC Agent crash [message #113957] |
Wed, 03 October 2007 09:50   |
Eclipse User  |
Originally posted by: romain.conseil.gmail.com
I try to use the non integrated ACAgent to profile a remote application.
The remote app runs on a linux RH4 and I try to profile on a windows XP
with eclipse europa and the last tptp plugin.
I use the last acagent version : agntctrl.linux_ia32-TPTP-4.4.0.3 de
ACAgent and i have set PATH, LD_LIBRARY_PATH and fixed the different
agent.xml files (\replaced by / and suppress .exe)
I can run the SampleClient without error on the linux plateform (port
10006) but when I try to run my java app (with the
-XrunpiAgent:server=enabled option) the ACAgent seems to crash and I have
this message in the shell :
Agent Controller is not active: will wait in a 1000 ms loop
The ACServer process is then killed and a core fil is generated :
(gdb) where
#0 0x01d5e66c in os::report_fatal_error () from
/usr/java/j2re1.4.2_06/lib/i386/server/libjvm.so
#1 0x01d5ee0f in os::handle_unexpected_exception () from
#2 0x01d62d76 in JVM_handle_linux_signal () from
#3 0x01d61b08 in signalHandler () from
#4 <signal handler called>
#5 0x00de2e33 in parseMessage () from ../lib/libtptpCmdExtr.so
#6 0x00de2994 in processMessage () from ../lib/libtptpCmdExtr.so
#7 0x00b9910b in processRecdMsgs () from ../lib/libsocketTL.so
#8 0x00b9925b in processClientRequest () from ../lib/libsocketTL.so
#9 0x00116371 in start_thread () from /lib/tls/libpthread.so.0
#10 0x00280ffe in clone () from /lib/tls/libc.so.6
(gdb)
I also have a message in the ptpParseError.log :
(09/03/07 10:41:33 ACServer) XML Error: Invalid document structure (error
detected at line:1, col:1, in "parseMessage()")
DO you have an idea ? I have done something wrong or is there a bug in the
ACAgent ?
Of course it is impossible to see any agent in the profileDialog of
eclipse but  I can connect to the host on the 10006 port (connection test
success) which is weird since ACServer is down...
Thanks a lot for your help !
| Re: Non Integrated AC Agent crash [message #113998 is a reply to message #113970] |
Wed, 03 October 2007 10:33    |
Eclipse User  |
Hi Igor,
and thanks for your answer,
here is the content of the servicelog.log :
<CommonBaseEvent creationTime="2007-10-03T08:40:47.034720Z"
globalInstanceId="A703558F0000877B5985CC5D7FD1301A" msg="Received command
for unrecognized interface: iid=org.eclipse.tptp.eventProvider,
cmd=listenerAccepted" severity="50" version="1.0.1">
	<sourceComponentId component="AgentController"
componentIdType="TPTPComponent" executionEnvironment="Connect2AC.c, line
2238" instanceId="1004" location="ocmt4.tls.fr.astrium.corp"
locationType="IPV4" processId="11455" subComponent="Client Compatibility
TL" threadId="11455" componentType="Eclipse_TPTP"/>
	<situation categoryName="ReportSituation">
		<situationType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
	</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2007-10-03T08:40:48.924979Z"
globalInstanceId="A7035590000E1D1F3AE2B2A402533B4C" msg="File server
started listening on port 10005" severity="10" version="1.0.1">
componentIdType="TPTPComponent" executionEnvironment="fileServer.c, line
177" instanceId="1004" location="ocmt4.tls.fr.astrium.corp"
	</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2007-10-03T08:40:54.099431Z"
globalInstanceId="A7035596000184507BF665FA32212BA9" msg="Incoming
connection request from agent Java Profiling Agent in process 11617 with
uuid UUID-1191400854-92723-442489449-998779012" severity="10"
version="1.0.1">
componentIdType="TPTPComponent" executionEnvironment="RACmdHandlers.c,
line 42" instanceId="1005" location="ocmt4.tls.fr.astrium.corp"
locationType="IPV4" processId="11455" subComponent="Agent Compatibility
	</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2007-10-03T08:40:54.099825Z"
globalInstanceId="A7035596000185E834D1137B5718BF00" msg="Registered Agent
UUID-1191400854-92723-442489449-998779012." severity="10" version="1.0.1">
line 99" instanceId="1005" location="ocmt4.tls.fr.astrium.corp"
	</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2007-10-03T08:40:55.130057Z"
globalInstanceId="A70355970001FBF27D69D6A540C2BE6D" msg="Registering
process 11617 org.eclipse.tptp.legacy.Java Profiling Agent" severity="10"
version="1.0.1">
1217" instanceId="1004" location="ocmt4.tls.fr.astrium.corp"
	</situation>
</CommonBaseEvent>
Concerning JVMTI / JVMPI, I will have a look to it but since I run my app
with jre 1.4.2_06, maybe it will be impossible to use JVMTI profiling...
Thanks for your help...
FUDForum. Page generated in 0.05130 seconds
