Problem opening saved diagram [message #113927] |
Fri, 23 March 2007 07:32  |
Originally posted by: francoscavuzzo.gmail.com
En blancoHi!
I have a problem. I generated an editor from my EMF model using GMF. While
testing the editor in Eclipse, I create a new diagram using the wizard, then
I save and close it. Then I reopen the saved diagram and it's OK. But, if
I close Eclipse (with the saved diagram in the workspace) and reopen it;
when I try to open my saved diagram I get this exception:
org.eclipse.emf.transaction.util.TransactionUtil.getEditingD omain(TransactionUtil.java:58)
org.eclipse.gmf.runtime.diagram.ui.resources.editor.document .DiagramModificationListener. <init>(DiagramModificationListener.java:55)
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.FileDiagramModificationListener. <init>(FileDiagramModificationListener.java:54)
org.isistan.flabot.executionstatemapping.model.diagram.part. ModelDocumentProvider$CustomModificationListener. <init>(ModelDocumentProvider.java:167)
org.isistan.flabot.executionstatemapping.model.diagram.part. ModelDocumentProvider.createFileInfo(ModelDocumentProvider.j ava:114)
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.FileDocumentProvider.createElementInfo(FileDocumentProv ider.java:486)
org.eclipse.gmf.runtime.diagram.ui.resources.editor.document .AbstractDocumentProvider.connect(AbstractDocumentProvider.j ava:387)
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.doSetInput(DiagramDocumentEditor.java:42 6)
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.setInput(DiagramDocumentEditor.java:389)
at org.eclipse.gef.ui.parts.GraphicalEditor.init(GraphicalEdito r.java:318)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.init( DiagramEditor.java:638)
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.init(DiagramDocumentEditor.java:116)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:842)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:583)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:372)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:263)
org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1474)
at org.eclipse.ui.internal.EditorManager$5.run(EditorManager.ja va:1008)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
org.eclipse.ui.internal.EditorManager.restoreState(EditorMan ager.java:1003)
org.eclipse.ui.internal.WorkbenchPage.restoreState(Workbench Page.java:2843)
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1936)
at org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.j ava:2873)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:2 821)
at org.eclipse.ui.internal.Workbench$20.run(Workbench.java:1697 )
org.eclipse.ui.internal.Workbench.runStartupWithProgress(Wor kbench.java:1437)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1695)
at org.eclipse.ui.internal.Workbench.access$12(Workbench.java:1 666)
at org.eclipse.ui.internal.Workbench$18.run(Workbench.java:1545 )
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1489)
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:183)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:702)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1101)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1863)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:422)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
If I create a new diagram from the wizard; and then try to open the saved
diagram it is opened correctly.
I think the wizard initialize something.
Any suggestions?
Thanks in advance.
FUDForum. Page generated in 0.06891 seconds
