Home » Archived » BIRT » How to pass databse details at run time to the report
How to pass databse details at run time to the report [message #110837] Wed, 18 January 2006 10:19 Go to next message
Originally posted by: buday.metrikus.com
i wnat to pass databse details to the report at runtime
is there any way to pass those details at runtime?
pls help me in this aspect..
Thank you...
Re: How to pass databse details at run time to the report [message #110849 is a reply to message #110837] Wed, 18 January 2006 10:26 Go to previous message
Originally posted by: jan.tanis.coas.com
If you mean to query dynamically like "SELECT * FROM CUS WHERE ID =
$PARAM$" you should watch the tutorial movie on this topic.
http://www.eclipse.org/downloads/download.php?file=/birt/dow nloads/demos/parameter_demo.wmv&r=1
Good luck.
PS: If you don't mean this, then consider this reply unmade;)
Regards, Jan.
boni.uday wrote:
> Thank you...
Re: How to pass databse details at run time to the report [message #110940 is a reply to message #110837] Wed, 18 January 2006 09:05 Go to previous message
If you look at the properties for the Data Source you will see a Property
Binding item in the left frame.
JDBC Driver Class, URL, User Name, and Password can be changed. You can set
these properties using report parameters.
For example User Name can be set to params["user"].
Jason Weathersby
BIRT PMC
"boni.uday" <buday@metrikus.com> wrote in message
news:c5789ae405b9c78a4ee0371d8429e9f7$1@www.eclipse.org...
> Thank you...
Previous Topic:Birt Exception occured
Next Topic:BIRT Assertion Failed Error
Current Time: Sat Nov 08 06:39:16 EST 2025
Powered by FUDForum. Page generated in 0.03636 seconds
