| Auto-Refresh [message #110624] |
Fri, 21 October 2005 06:22  |
Originally posted by: dheepuks.yahoo.co.in
I have copied a file from one location to another location. I have to
display the file in a tree node. the file is being copied well and get
struck in node.
But to view the file in the node i will have to refresh the tree node
manually by pressing F5 key.then only its getting displayed.
i have used
1.
MyNavigator nav = MyData.getInstance().getMyView(true);
nav.getViewer().refresh(); // refreshes the view part
2.
try
IWorkspaceRoot root = ResourcesPlugin.getWorkspace().getRoot();
IProject myProj = root.getProject(Const.MY_PROJECT);
myFolder = myApp.getFolder(Const.MY_FOLDER);
IFolder folder = myFolder;
folder.refreshLocal(IResource.FORCE, null);
catch(Exception ex)
ex.printStackTrace();
i have tried with given 1, 2 steps but its not getting refreshed
automatically.
i have used
java.nio.channels.FileChannel
to copy the files.
FileChannel dstChannel = new FileOutputStream(path1).getChannel();
dstChannel.transferFrom(source, 0, source.size());
please let me know
Thanks in advance.
| Re: Auto-Refresh [message #111120 is a reply to message #110624] |
Mon, 24 October 2005 12:14  |
Originally posted by: john.eclipsefaq.org
Is this your own view or the Navigator that is not refreshing?
Generally, a viewer never needs to be manually refreshed from outside.
The viewer will listen for changes to the underlying model (the
workspace in this case), and update itself accordingly. So, simply
changing the underlying model will cause the viewer to update itself.
If you are modifying a file in the workspace diretly using java.nio, you
will need to refresh the IResource, as you are doing in snippet #2.
Dheepu Kumar wrote:
> struck in node.
> i have used 1. MyNavigator nav = MyData.getInstance().getMyView(true);
> 2.
> try
> folder.refreshLocal(IResource.FORCE, null); }
> catch(Exception ex)
> automatically.
> i have used java.nio.channels.FileChannel to copy the files.
> please let me know
> Thanks in advance.
FUDForum. Page generated in 0.09930 seconds
