Home » Archived » Test and Performance Tools Platform (TPTP) » Missing "Collect object references"
Missing "Collect object references" [message #108971] Tue, 14 August 2007 08:55 Go to next message
Originally posted by: johan.piculell.ericsson.com
Hi. Just tried the memory analysis (TPTP 4.4 on Eclipse 3.3) and wanted to
check object references but I don't have the "Collect object references"
button. Is this a known bug or something that I forgot to configure?
I need to say that I'm using Java 6.0 even though I know it is not 100%
supported, but everything else seems ok apart from this missing button.
Thanks for a cool set of feature plug-ins!
regard
/Johan
Re: Missing "Collect object references" [message #109045 is a reply to message #108971] Wed, 15 August 2007 01:45 Go to previous message
> to check object references but I don't have the "Collect object
> references" button. Is this a known bug or something that I forgot to
> configure?
> regard
> /Johan
This is a known limitation rather than a bug. The new profiler in TPTP
4.4 does not yet support the feature of "collect object references". If
you want to use this feature, use a Java 1.5 JVM and select the "Java
1.5-" data collector in the Monitor tab.
HTH,
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Previous Topic:AGR 4.3 -> AGR 4.4
Next Topic:[AGR] Ant execution blues
Current Time: Thu Nov 06 04:42:30 EST 2025
Powered by FUDForum. Page generated in 0.02626 seconds
