Home » Modeling » GMF (Graphical Modeling Framework) » any users of GMF 2.0M5 on Linux/GTK?
any users of GMF 2.0M5 on Linux/GTK? [message #108031] Thu, 01 March 2007 03:57 Go to next message
Do you use GMF 2.0M5 on Linux/GTK? And if so, do you have problems
such as black pixels on icons with transparency or not working
window refreshing after opening Properties View for diagram's element?
Seweryn Niemiec
Re: any users of GMF 2.0M5 on Linux/GTK? [message #108149 is a reply to message #108031] Thu, 01 March 2007 06:42 Go to previous messageGo to next message
Seweryn Niemiec wrote:
> Hi
> Seweryn Niemiec
I've got the same problem with black pixels on Ubuntu edgy. I'm working
with Eclipse 3.3M4
Re: any users of GMF 2.0M5 on Linux/GTK? [message #108206 is a reply to message #108149] Thu, 01 March 2007 08:05 Go to previous messageGo to next message
Thu, 01 Mar 2007 12:42:35 +0100, Youmm P.:
> with Eclipse 3.3M4
You can vote for this bug here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=152276
Re: any users of GMF 2.0M5 on Linux/GTK? [message #108451 is a reply to message #108206] Fri, 02 March 2007 08:12 Go to previous messageGo to next message
I although have a display problem with underscores. They aren't
displayed, for instance in the topic name of the mindmap example.
Re: any users of GMF 2.0M5 on Linux/GTK? [message #108508 is a reply to message #108451] Fri, 02 March 2007 08:50 Go to previous message
Hi Youmm
Most of the Display problems that happens on Linux are cause because of
an AdvancedGraphic issues in the Cairo Library in linux
to check if this is your cause try to use the Logic Diagram or the
Ecore diagram Example, and see if the problem is reproducible there
If it is reproducible in any of them, then go to the preferences page
of that diagram turn off Anti Aliasing. And see if this will help
Issues that Advanced Graphics cause on Linux or Windows XP
RTL broken on Windows
RTL and DBCS disappear on Linux
Transparency is broken on some icons specially while dragging (Linux
and windows)
Text Wrapping is broken with some fonts
i believ that the SWT team had fixed some of these issues, but i'm not
sure if it is in the latest EClipse build or not
Previous Topic:Strange behavior of nodes in a compartment
Next Topic:Problem creating links programatically using CreateRelationshipRequest
Current Time: Fri Sep 19 00:40:22 EDT 2025
Powered by FUDForum. Page generated in 0.37476 seconds
