Home » Archived » M2M (model-to-model transformation) » [ATL] several Resources in a ResourceSet
[ATL] several Resources in a ResourceSet [message #105706] Wed, 27 May 2009 07:02 Go to next message
Hi all,
If a resource set (for the source model) contains several resources it
seems like the transformation considers only the first one.
Is there a way that all Resources are processed?
Henrik
Re: [ATL] several Resources in a ResourceSet [message #106248 is a reply to message #105706] Tue, 09 June 2009 02:45 Go to previous messageGo to next message
to be more precise I should add that the Resources are not cross-linked
by EMF References
Henrik Rentz-Reichert wrote:
> Hi all,
> Henrik
Re: [ATL] several Resources in a ResourceSet [message #106276 is a reply to message #106248] Tue, 09 June 2009 04:58 Go to previous messageGo to next message
Henrik,
ATL transformations take one or more models as input, they do not
talke a resource set.
Andy.
"Henrik Rentz-Reichert" <hrr@protos.de> wrote in message
news:h0l0e2$gsp$1@build.eclipse.org...
> by EMF References
>> Hi all,
>> Regards,
>> Henrik
Re: [ATL] several Resources in a ResourceSet [message #106299 is a reply to message #106276] Tue, 09 June 2009 05:46 Go to previous messageGo to next message
Andy,
sure, they take models. But if I use EMF models somewhere a
EMFModelFactory and a EMFInjector enter the game.
Does that mean (provided the pre-installed factories behave not the way
I like) I have to register my own versions?
And if so, can you point me to an example how this is done?
Henrik
Andy Carpenter wrote:
> Henrik,
> Andy.
>> by EMF References
>>> Hi all,
>>> Regards,
>>> Henrik
Re: [ATL] several Resources in a ResourceSet [message #106360 is a reply to message #106299] Tue, 09 June 2009 08:38 Go to previous message
Here you can find documentation about that concepts:
http://wiki.eclipse.org/ATL/Developer_Guide#Core
The part you want to extend is defined under the following plugin:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.core/?root=Mode ling_Project
And here you can find two implementations of the core concepts (IModel,
ModelFactory and so on):
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.core.emf/?root= Modeling_Project
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.core.ui.vm/?roo t=Modeling_Project
William
Henrik Rentz-Reichert a écrit :
> Andy,
> Henrik
>> Henrik,
>> Andy.
>>> by EMF References
>>>> Hi all,
>>>> Regards,
>>>> Henrik
Previous Topic:[ATL] developing a transformation and the target model in parallel
Next Topic:[ATL] SideEffect example - ant build doesn't work
Current Time: Fri Nov 07 12:55:53 EST 2025
Powered by FUDForum. Page generated in 0.03641 seconds
