Home » Archived » Test and Performance Tools Platform (TPTP) » gla adapter
gla adapter [message #9550] Wed, 09 March 2005 10:30 Go to next message
Originally posted by: mujtaba.alsaif.brunel.ac.uk
hi,
i was wondering if it was possible to setup wild cards to import in the
log files rather then predefine the logs files?
Mujtaba
Re: gla adapter [message #11357 is a reply to message #9550] Mon, 21 March 2005 10:19 Go to previous messageGo to next message
Hi Mujtaba,
Unfortunately, this function is not supported. Please open an
enhancement request:
http://www.eclipse.org/tptp/ >> Submit Enhancements and Bugs
Paul
"mujtaba" <mujtaba.alsaif@brunel.ac.uk> wrote in message
news:d0n4rg$5em$1@www.eclipse.org...
> hi,
> Mujtaba
Re: gla adapter [message #13428 is a reply to message #11357] Fri, 01 April 2005 12:58 Go to previous message
Originally posted by: nobody.nobody.com
Mujtaba,
That functionality is available starting in Hyades 3.2. You can use regular
expressions in the log file field in the import wizard to specify multiple
files (of the same type) to import.
Here is the note in the Log And Trace documentation:
Note 2: You can import multiple log files at once by specifying a regular
expression in the path field. For example, to import all the logs in the
d:\temp directory, enter d:\temp\.* in the field. Follow the regurlar
expression rules of java.util.regex.Pattern.
The GLA runtime supports regular expressions for the fileName field in the
sensor component configuration.
Dave
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:d1mtd1$ihk$1@news.eclipse.org...
> Hi Mujtaba,
> Paul
> > hi,
> > Mujtaba
Previous Topic:Porting Custom Test Exec Demo to TPTP 4.0
Next Topic:Profiling JBoss
Current Time: Fri Nov 28 06:56:14 EST 2025
Powered by FUDForum. Page generated in 0.04392 seconds
