| Re: [buckminster-dev] headless resolve with properties [message #9531] |
Thu, 13 March 2008 15:27 |
Hey Adrian,
Thanks again for the tip. I have a couple of questions I'm wondering if you
can clarify on importing from a local SDK:
- what ReaderType do you use for the provider, is it eclipse.import or
eclipse.platform?
- did you actually create a local update site (I was under the impression
that eclipse.import was used pretty much exclusively with update sites...)
or are you just pointing it to a directory with an extracted Eclipse
SDK.zip?
If it's not asking too much, perhaps I'd be able to get a better handle on
this if you could provide a sample snippet from your RMAP/setup?
Todd
Hi Todd,
Not sure if this is exactly what you need but I just use an importer
in my rmap to pull the required plugins from the SDK that I would be
doing the materialising in. So I'm able to resolve all the OSGi based
dependencies fine, it's when it comes to maven that I'm getting
unstuck right now. Once I find someway of overcoming this, my plan
was to use buckminster to install all the plugins / features it would
need from org.eclipse prior to kicking off the resolve. Then it should
automatically resolve those plugins from its own plugin repository. I
was going to automate this from within an ant script.
Stability wise I think the latest version appears to be better than
those prior to it so I wouldn't recommend going back in version.
HTH,
Adrian.
AMI Semiconductor - "Silicon Solutions for the Real World"
NOTICE:
This electronic message contains information that may be confidential or privileged. The information is intended for the use of the individual or entity named above. If you are not the intended recipient, please be aware that any disclosure, copying, distribution or use of the contents of this information is prohibited. If you received this electronic message in error, please notify the sender and delete the copy you received.
FUDForum. Page generated in 0.03910 seconds
