Home » Archived » Test and Performance Tools Platform (TPTP) » ExecutionTimeAnalysis + MemoryAnalysis
ExecutionTimeAnalysis + MemoryAnalysis [message #104327] Wed, 11 July 2007 13:43 Go to next message
Originally posted by: codex.magic-dreams.de
I want to do a ExecutionTimeAnalysis and MemoryAnalysis together for an
application (a JUnit testsuite). I can only select ExecutionTimeAnalysis
OR MemoryAnalysis but not togehter in the Monitor-tab.
Wolfgang
Re: ExecutionTimeAnalysis + MemoryAnalysis [message #104345 is a reply to message #104327] Wed, 11 July 2007 14:35 Go to previous messageGo to next message
I see this also, previous releases allow single, subset, or All profiling
options to be selected. This release does not.
Re: ExecutionTimeAnalysis + MemoryAnalysis [message #104522 is a reply to message #104327] Thu, 12 July 2007 07:30 Go to previous messageGo to next message
Hi Wolfgang,
In TPTP 4.4, only one type of Java Profiling data collector can be
selected at once.
Paul
"Wolfgang Roessler" <codex@magic-dreams.de> wrote in message
news:f734qg$1p6$1@build.eclipse.org...
> Hello,
> Regards
> Wolfgang
Re: ExecutionTimeAnalysis + MemoryAnalysis [message #104565 is a reply to message #104522] Thu, 12 July 2007 09:53 Go to previous messageGo to next message
Wolfgang,
This only applies to when you are profiling using the TI agent (1.5 or
later). When profiling with the PI Agent (pre 1.5) you can still select two
datacollectors in TPTP 4.4.
Paul
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:f753d2$e5q$1@build.eclipse.org...
> Hi Wolfgang,
> selected at once.
> Paul
>> Hello,
>> Regards
>> Wolfgang
Re: ExecutionTimeAnalysis + MemoryAnalysis [message #104609 is a reply to message #104565] Thu, 12 July 2007 14:13 Go to previous messageGo to next message
oddly enough I have a bit of a dice roll when selecting the 1.5 or 1.5
profiling. about 1/2 the time the profile tab does not show the 1.4
approach as an option. Typically, when I select the Monitor tab a string
"Pending..." flickers for a oment and them my options appear. The
"pre-1.5" is not always offered.
Re: ExecutionTimeAnalysis + MemoryAnalysis [message #104662 is a reply to message #104609] Fri, 13 July 2007 06:47 Go to previous messageGo to next message
Hi Mike,
This appears to be a defect. Can you open a Bugzilla for this behavior?
Paul
"mike shipkowski" <michael.shipkowski@sas.com> wrote in message
news:f3b21b51601e338a059ab98aedf36b12$1@www.eclipse.org...
Re: ExecutionTimeAnalysis + MemoryAnalysis [message #105035 is a reply to message #104609] Sun, 15 July 2007 04:44 Go to previous messageGo to next message
> string "Pending..." flickers for a oment and them my options appear.
> The "pre-1.5" is not always offered.
When you click the Monitor tab, the UI communicates with the Agent
Controller (integrated or standalone, depending on your configuration)
to determine the version of the Java runtime. It then shows the
collectors appropriate for the detected versions. This check is bound by
a very short timeout. When it expires, all collectors (pre and post 1.5)
are shown.
If you would like to use the pre-1.5 collectors, make sure that you
Agent Controller uses a Java 1.4 or 5 JRE.
HTH,
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Re: ExecutionTimeAnalysis + MemoryAnalysis [message #105055 is a reply to message #105035] Mon, 16 July 2007 11:29 Go to previous messageGo to next message
Since TPTP 4.4, PI profiler is only available for selection when JVM
setting of Agent Controller is JVM 1.4, and TI profiler is only available
when Agent Controller is configured with JVM 1.5.
There are two different type of Agent Controller available, and they are
RAC (remote agent controller) and IAC (integrated agent controller). IAC
supports only local profiling while RAC supports both local and remote
profiling. If RAC is not runing or started by user in local use case, IAC
will automatically startup when profile is started. RAC on the other hand
is always required running on the target machine for remote profiling.
JVM setting of RAC is configured by running the setConfig.bat file. IAC
configures itself and always run with the JVM selection in Workbench
Windows > Preferences... > Java > Installed JREs.
Re: ExecutionTimeAnalysis + MemoryAnalysis [message #105104 is a reply to message #105035] Mon, 16 July 2007 14:43 Go to previous message
Understood...the main concern is the same set of profile options 1.5 or
1.4 is not offered each time I run using the same eclipse, machine, task
to monitor.
Previous Topic:[TPTP AGR] Running in Standard Mode with fixed size and position
Next Topic:Acceptance testing and RCP applications
Current Time: Sat Oct 18 04:47:58 EDT 2025
Powered by FUDForum. Page generated in 0.11168 seconds
