Home » Language IDEs » ServerTools (WTP) » XML schema viewer suggestion
XML schema viewer suggestion [message #101886] Tue, 10 May 2005 06:37 Go to next message
Originally posted by: adamNoSpam_._NoSPAMsoftfab.com
What schema.
Many schemas I have to work with are at the end of a long chain of
schemas i.e. I might be working on a schema which incudes a schema which
itself includes a schema etc.etc.
When you are then using the schema viewer & you get to an element which
is some distance into the model/tree you then have no idea which actual
schema contains the definition. What would be very usefull would be the
ability to see which actual schema contains a chosen type.
e.g. in the properties view you could include a further textbox which
says which schema this type resides in (& possibly the abilty to open
that schema in another tab).
Adam
Re: XML schema viewer suggestion [message #102097 is a reply to message #101886] Tue, 10 May 2005 15:33 Go to previous message
Good suggestions, please open a bugzilla bug for this enhancement. As
always I'm happy to walk youe through code if you'd like to implement this
change.
Previous Topic:WTP XML Editor Tab width
Next Topic:How to open a browser Window from M4?
Current Time: Sun Nov 09 02:35:11 EST 2025
Powered by FUDForum. Page generated in 0.03704 seconds
