| Novice question on the use of static introductions [message #9264] |
Fri, 25 October 2002 14:38  |
Originally posted by: john_daly.hp.com
I'm attempting to use static introductions in a code based with the
following package structure and would like to have the stated
introductions weaved into all classes from 'src' package down recursively.
Package Structure
src (main package)
src.shp (shape package including a sample shape class: Shape.java)
src.shp.tst (tst packagge including sample test class: Test.java)
src.log (log package including sample logger aspect: Logger.java)
Logger Aspect
public aspect Logger
public static void (src.*.*.*).fatal(Object message)
System.out.println(message);
In the code above the 'src.*.*.*' introduces the method 'fatal' only into
the
'Test.java' class found in 'src.shp.tst'but not into any of the classes
above it in the package hierarchy.
Is there a syntax for specifying all classes in all packages below a
certain package level? I'm thinking of something similar to the mechanism
for selecting subtypes(i.e. Shape+)but have been unsuccessful in determing
if such a selection mechanism exists.
Thanks in advance for any pointers or thoughts.
| Re: Novice question on the use of static introductions [message #9349 is a reply to message #9325] |
Mon, 28 October 2002 11:51  |
Julie,
Thanks for the response and sorry for the incorrect newsgroup post.
-jd
Julie Waterhouse wrote:
> Hi John,
> The wildcard pattern src..* will match every class in the src package, its
> subpackages, and inner classes. (You could also be more specific with
> src.shp..* etc if you wanted).
> FYI for the future, the best place to ask these kinds of questions is on
> the AspectJ mailing list. See
http://aspectj.org/servlets/AJSite?channel=userCommunity& ;subChannel=mailingLists
> This newsgroup is primarily for issues dealing with the AJDT plugin to
> Eclipse.
> Julie Waterhouse
> AJDT Development Team
> John Daly wrote:
> > Hello,
> > I\\\'m attempting to use static introductions in a code based with the
> > introductions weaved into all classes from \\\'src\\\' package down
recursively.
> > Package Structure
> > src (main package)
> > Logger Aspect
> > In the code above the \\\'src.*.*.*\\\' introduces the method
\\\'fatal\\\' only into
> > the
> > \\\'Test.java\\\' class found in \\\'src.shp.tst\\\'but not into any of
the classes
> > certain package level? I\\\'m thinking of something similar to the
mechanism
| Re: Novice question on the use of static introductions [message #562367 is a reply to message #9264] |
Mon, 28 October 2002 08:20  |
Hi John,
Eclipse.
Julie Waterhouse
John Daly wrote:
> Hello,
> I\'m attempting to use static introductions in a code based with the
> introductions weaved into all classes from \'src\' package down recursively.
> Package Structure
> src (main package)
> Logger Aspect
> In the code above the \'src.*.*.*\' introduces the method \'fatal\' only into
> the
> \'Test.java\' class found in \'src.shp.tst\'but not into any of the classes
> certain package level? I\'m thinking of something similar to the mechanism
| Re: Novice question on the use of static introductions [message #562391 is a reply to message #9325] |
Julie,
-jd
> Hi John,
> Eclipse.
> Julie Waterhouse
> John Daly wrote:
> > Hello,
recursively.
> > Package Structure
> > src (main package)
> > Logger Aspect
> > the
the classes
mechanism
FUDForum. Page generated in 0.03321 seconds
