Home » Archived » Test and Performance Tools Platform (TPTP) » How do i perform automation testing
| How do i perform automation testing [message #100170] |
Tue, 05 June 2007 05:42  |
Hi friends,
I m new to TPTP - AGR... and also automation testing...
I would like to know how do i perform automation testing using AGR ?
Suppose i record UI events, save the file and run it in standard mode, i
get some verdict, here my question is,
1. on what basis does the tool generate a verdict ??
2. How can i perform automation testing in a project??
3.
| Re: How do i perform automation testing [message #100241 is a reply to message #100170] |
Tue, 05 June 2007 17:48   |
------=_NextPart_000_0007_01C7A799.AC1DAF90
Content-Type: text/plain;
charset="iso-8859-15"
Hi Amit,
Thanks for your interest in the AGR.
For a full tutorial on how to get started with the AGR including how to =
write and execute Automated GUI tests with TPTP, please see:
http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI-4-4-=
0.html
To answer your other question, the runner will report a failure if any =
of the commands fail on playback (for example, if an item-select cannot =
resolve the widget it is to select). Most often, it is a resolution =
failure for which you will see the Macro line on which it failed and a =
brief description of the failure. Sometimes, it may be a time out (while =
waiting for a job to complete or waiting for a dialog to appear).
Failures can also be caused by assertion failures in verification hooks. =
These will be reported as such in the execution results, giving the name =
of the verification class and the line on which it failed.
Please let me know if you have further questions once you get started.
Sincerely,
Liz Dancy
"Amit" <amitsimu@tataelxsi.co.in> wrote in message =
news:fa18cdd14a56be91b7b33a0a719ecbea$1@www.eclipse.org...
> Hi friends,
>=20
> Suppose i record UI events, save the file and run it in standard mode, =
i=20
> get some verdict, here my question is,=20
> 2. How can i perform automation testing in a project??=20
> 3.=20
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-15">
<META content=3D"MSHTML 6.00.2900.3059" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>Hi Amit,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Thanks for your interest in the =
AGR.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>For a full tutorial on how to get =
started with the=20
AGR including how to write and execute Automated GUI tests with TPTP, =
please=20
see:</FONT></DIV>
<DIV><A=20
href=3D" http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-=
GUI-4-4-0.html"><FONT=20
face=3DArial=20
size=3D2> http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto=
-GUI-4-4-0.html</FONT></A></DIV>
<DIV><FONT face=3DArial size=3D2>To answer your other question, =
</FONT><FONT=20
face=3DArial size=3D2>the runner will report a failure if any =
of the=20
commands fail on playback (for example, if an item-select cannot resolve =
the=20
widget it is to select). Most often, it is a resolution failure for =
which you=20
will see the Macro line on which it failed and a brief description of =
the=20
failure. Sometimes, it may be a time out (while waiting for a job to =
complete or=20
waiting for a dialog to appear).</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Failures can also be caused by =
assertion failures=20
in verification hooks. These will be reported as such in the execution =
results,=20
giving the name of the verification class and the line on which it=20
failed.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT><FONT face=3DArial =
size=3D2>Please let me know=20
if you have further questions once you get started.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Sincerely,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Liz Dancy</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>"Amit" <</FONT><A=20
href=3D"mailto:amitsimu@tataelxsi.co.in"><FONT face=3DArial=20
size=3D2>amitsimu@tataelxsi.co.in</FONT></A><FONT face=3DArial =
size=3D2>> wrote in=20
message </FONT><A=20
href=3D"news:fa18cdd14a56be91b7b33a0a719ecbea$1@www.eclipse.org"><FONT =
face=3DArial=20
size=3D2>news:fa18cdd14a56be91b7b33a0a719ecbea$1@www.eclipse.org</FONT></=
A><FONT=20
face=3DArial size=3D2>...</FONT></DIV><FONT face=3DArial size=3D2>> =
Hi=20
friends,<BR>> I m new to TPTP - AGR... and also automation =
testing...<BR>>=20
<BR>> I would like to know how do i perform automation testing =
using AGR=20
?<BR>> Suppose i record UI events, save the file and run it in =
standard mode,=20
i <BR>> get some verdict, here my question is, <BR>> 1. on what =
basis does=20
the tool generate a verdict ??<BR>> 2. How can i perform automation =
testing=20
in a project?? <BR>> 3. <BR>></FONT></BODY></HTML>
------=_NextPart_000_0007_01C7A799.AC1DAF90--
| Re: How do i perform automation testing [message #100270 is a reply to message #100170] |
Wed, 06 June 2007 00:50  |
Thanks for your prompt reply, but i am facing a problem such as,
if i record a test case and run it in standard mode, it gives a verdict
saying pass. and when i run it for the second time or something the
verdict may change, so i am not understanding what d problem is.
Secondly, whenever the test fails or something, is d info given sufficient
for d developers to find out the defect ?
Thirdly, i have gone through the tutorial, but still am facing problems,
since the latter part is complex (after the context creation). Actually i
want to know how automation testing is usually done in a project.
is it like i run d script for Ex: build 1.0 and run d same script again
and check for the result for build 1.1 ?
Thank You,
Amit
Current Time: Thu Nov 20 06:53:12 EST 2025
Powered by FUDForum. Page generated in 0.11479 seconds
