Home » Eclipse Projects » Eclipse Platform » View: How to change the Icons
View: How to change the Icons [message #98575] Wed, 23 July 2003 12:28 Go to next message
I have build an plugin based on the view template.
Now I want to change the icons in the treeview.
Unfortunately I dont know, which class is setting the icons.
Which classes should I look at?
Every hint is welcome.
TIA + Regards,
Frank
Re: How to change the Icons [message #98915 is a reply to message #98575] Wed, 23 July 2003 22:44 Go to previous message
Originally posted by: hlyiu.hotmail.com
I am working on it also.
LabelProvider controls the image and text for the tree node, you need to set
getImage(Object element) in LabelProvider.
Check out setLabelProvider method in TreeViewer.
Davis
"Frank Fischer" <ff@semoe.de> ???????:bfmd30$eko$1@eclipse.org...
> TIA + Regards,
> Frank
Previous Topic:War file question
Next Topic:How do you set up a remote QuickDiff reference provider? (3.0 M2)
Current Time: Wed Nov 19 02:21:18 EST 2025
Powered by FUDForum. Page generated in 0.03508 seconds
