Home » Eclipse Projects » Equinox » Using Log4j in Equinox
Using Log4j in Equinox [message #96911] Mon, 10 September 2007 10:51 Go to next message
I've created a bundle that intends to use log4j to log all the entries
in the framework. The idea is that a custom Listener will be registered
in LogReaderService and when it is called it will log to a file using
the capabilities of log4j.
The problem I'm having is that every time I start the bundle I get the
following error:
osgi> log4j:WARN No appenders could be found for logger (root).
log4j:WARN Please initialize the log4j system properly.
The class I'm using for listener is a very simple one, just to start
with a simple test:
package logger.file;
import org.apache.log4j.Logger;
import org.osgi.service.log.LogEntry;
import org.osgi.service.log.LogListener;
public class HUMSFileLogListener implements LogListener {
static Logger logger = Logger.getLogger(HUMSFileLogListener.class);
* (non-Javadoc)
* @see
org.osgi.service.log.LogListener#logged(org.osgi.service.log .LogEntry)
public void logged(LogEntry logEntry) {
logger.debug("Log4J: "+ logEntry.getBundle().getSymbolicName() + " " +
logEntry.getMessage());
System.err.println("Sysout: " + logEntry.getBundle().getSymbolicName()
+ " " + logEntry.getMessage());
My log4.properties is also very simple for this example:
# Set root logger level to DEBUG and its only appender to A1.
log4j.rootLogger=DEBUG, A1
# A1 is set to be a ConsoleAppender.
log4j.appender.A1=org.apache.log4j.ConsoleAppender
# A1 uses PatternLayout.
log4j.appender.A1.layout=org.apache.log4j.PatternLayout
log4j.appender.A1.layout.ConversionPattern=%-4r [%t] %-5p %c %x - %m%n
So If all went well I should have two output lines in the consolebut all
I got is this just after the equinox starts:
(logger.file.HUMSFileLogListener).
C-HUMS: FileLogger Added C-HUMS LogListener
C-HUMS: FileLogger Sarting C-HUMS Log
I'm thinking the problem migth by with the location of the
log4j.properties file... I'm placing it in the root of my project so it
can be at the root of my jar.
As anyone done this successfully?
Thanks in advance,
Pedro Silva
Re: Using Log4j in Equinox [message #96920 is a reply to message #96911] Mon, 10 September 2007 12:00 Go to previous messageGo to next message
I've managed to put it to work :) The solution was to create a log4j
fragment bundle with the log4j.properties file inside.
Anyway I would like to hear from someone if this approach is the correct
one.
Pedro Silva
Pedro Silva wrote:
> following error:
> with a simple test:
> * (non-Javadoc)
> * @see
> logEntry.getBundle().getSymbolicName() + " " + logEntry.getMessage());
> Thanks in advance,
> Pedro Silva
Re: Using Log4j in Equinox [message #97032 is a reply to message #96920] Mon, 10 September 2007 19:39 Go to previous message
Originally posted by: alex_blewitt.yahoo.com
Yeah, that's pretty much the approach I suggested using in
http://www.eclipsezone.com/eclipse/forums/t99588.html
Alex.
Previous Topic:Problem with http.jetty and static content...
Next Topic:EclipseStarter.shutdown() freezes
Current Time: Fri Oct 17 06:17:45 EDT 2025
Powered by FUDForum. Page generated in 0.03553 seconds
