| [Teneo / JPOX]  java.lang.StringIndexOutOfBoundsException [message #92730] |
Wed, 08 August 2007 09:33   |
Eclipse User  |
Originally posted by: fc_supercanard.yahoo.fr
Hello Martin,
I am trying to import content into DB2 database from an xml file.
I initialize jpoxDataStore, then create resource to handle things.
Here is the exception :
Exception in thread "main" java.lang.StringIndexOutOfBoundsException
	at java.lang.String.substring(String.java:1088)
	at org.jpox.store.OID.<init>(OID.java:105)
 org.eclipse.emf.teneo.jpox.resource.JPOXResource.getEObjectB yID(JPOXResource.java:302)
 org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject( ResourceImpl.java:683)
 org.eclipse.emf.ecore.util.EObjectValidator.validate_UniqueI D(EObjectValidator.java:1095)
 org.eclipse.emf.ecore.util.EObjectValidator.validate_EveryDe faultConstraint(EObjectValidator.java:195)
 org.eclipse.emf.ecore.util.EObjectValidator.validate(EObject Validator.java:168)
 org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:127)
 org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:107)
 org.eclipse.emf.teneo.resource.NonLoadingDiagnostician.doVal idateContents(NonLoadingDiagnostician.java:49)
 org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:130)
	at  org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:87)
 org.eclipse.emf.teneo.resource.StoreResource.validateObject( StoreResource.java:421)
 org.eclipse.emf.teneo.resource.StoreResource.validateContent s(StoreResource.java:408)
 org.eclipse.emf.teneo.resource.StoreResource.save(StoreResou rce.java:353)
	at DatastoreInstall.importCars(DatastoreInstall.java:116)
	at DatastoreInstall.init(DatastoreInstall.java:37)
	at DatastoreInstall.main(DatastoreInstall.java:127)
I made a small testcase. I would be nice if you could take a look on it.
I have sent on your mail all the files that you should need.
Quentin
| Re: [Teneo / JPOX]  java.lang.StringIndexOutOfBoundsException [message #92867 is a reply to message #92852] |
Thu, 09 August 2007 04:30   |
Eclipse User  |
The bugzilla is created.
regards
Martin Taal wrote:
> Hi Quentin,
> Thanks for the testcase it really facilitated finding this issue. There
> is a bug in the StoreResource class in Teneo. I have solved this and
> checked it in. I hoped to get a new release out this week but I am not
> sure if I can manage that.
> As a workaround In the mean time you can create your own resource class
> by extending JpoxResource and overriding the attached method with the
> method below.
> The correct attached method is:
>     public void attached(EObject eObject) {
>         attachedHelper(eObject);
>         for (Iterator<EObject> tree =
> getNonResolvingContent(eObject).basicIterator(); tree.hasNext();) {
>             final Object obj = tree.next();
>             // before this called:
>             // attachedHelper((EObject) obj);
>             // however this resulted in child elements (which were
> loaded) not being
>             // added to the internal id map
>             attached((EObject) obj);
> Can you also create a bugzilla for this and attach the testcases you
> send me? Then I can add your testcases to the teneo test set.
> gr. Martin
> french.cancan wrote:
>> Hello Martin,
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>> Regards,
>> Quentin
| Re: [Teneo / JPOX]  java.lang.StringIndexOutOfBoundsException [message #609433 is a reply to message #92730] |
Wed, 08 August 2007 09:59   |
Eclipse User  |
Hi Quentin,
Okay, I will look at it this evening.
gr. Martin
> Hello Martin,
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
> Quentin
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: [Teneo / JPOX]  java.lang.StringIndexOutOfBoundsException [message #609440 is a reply to message #92730] |
Thu, 09 August 2007 00:51   |
Eclipse User  |
Hi Quentin,
Thanks for the testcase it really facilitated finding this issue. There is a bug in the
StoreResource class in Teneo. I have solved this and checked it in. I hoped to get a new release out
this week but I am not sure if I can manage that.
As a workaround In the mean time you can create your own resource class by extending JpoxResource
and overriding the attached method with the method below.
		for (Iterator<EObject> tree = getNonResolvingContent(eObject).basicIterator(); tree.hasNext();) {
			// however this resulted in child elements (which were loaded) not being
Can you also create a bugzilla for this and attach the testcases you send me? Then I can add your
gr. Martin
> Hello Martin,
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
> Quentin
The Netherlands
| Re: [Teneo / JPOX]  java.lang.StringIndexOutOfBoundsException [message #609441 is a reply to message #92852] |
Eclipse User  |
regards
Martin Taal wrote:
> Hi Quentin,
> method below.
> loaded) not being
> gr. Martin
>> Hello Martin,
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>> Regards,
>> Quentin
FUDForum. Page generated in 0.71925 seconds
