| PHP inside of Javascript in a .php file [message #90689] |
Thu, 15 January 2009 21:14  |
Originally posted by: micahjg26.netscape.net
I have Javascript code that I output inside of a PHP file, but put
variables inside the javascript block. I am getting a weird error:
<?php
function SomeFunction()
<script type="text/javascript">
parentValue = <?=$parentValue?>;
</script>
I get an error over the '<?' of the '<?=' expresssion in the javascript
block saying: Syntax error on tokens, PostfixExpression expected instead
Anyone know why this is?
Micah
| Re: PHP inside of Javascript in a .php file [message #90752 is a reply to message #90737] |
Fri, 16 January 2009 04:21   |
Nick Boldt wrote:
> Couple thoughts...
> 1. Try using fully-formed PHP, not the lazy <?= ?> format.
That didn't make a difference.
> 2. Try wrapping your javascript variable assignment (unless it's an
> integer!) with quotes.
They are integers, but it doesn't matter since I'm just passing them to
a PHP script with AJAX. This actually worked, but I have a new problem:
if (parentValue)
<?php echo $function;?>
gives me these errors:
Multiple annotations found at this line:
- Syntax error on token "<", invalid Expression
- Syntax error on token "?", invalid Expression
- Syntax error on token ">", FullPostfixExpression expected after this
token
- Syntax error on token "echo", : expected
- syntax error, unexpected 'EOF'
It seems like the Javascript parser has trouble with the PHP inside the
javascript, even though the javascript is in a PHP file.
> Thus:
> <?php
> parentValue = '<?php print $parentValue; ?>';
> </script>
> Or, better:
> <?php
> print<<<EOHTML
> parentValue = '${parentValue}';
> </script>
> EOHTML; // must be flushed to left margin
I might have to try this instead.
>> <?php
>> </script>
>> Thanks,
>> Micah
| Re: PHP inside of Javascript in a .php file [message #90843 is a reply to message #90782] |
Fri, 16 January 2009 13:02  |
Nick Boldt wrote:
> Micah wrote:
>> if (parentValue)
> What is the value of $function?
The name of a xajax function. This is while editing, not running that I
get the error.
>> this
>> token
> You might want to open a bug against PDT (or maybe this is a DLTK
> issue?) explaining what you've tried and what workarounds (if any) work
> to clear the reported errors.
I'll have to do that. I just wanted to make sure that I wasn't missing
a config setting before filing a bug.
> Sounds like there are parser usecases not yet implemented.
> Have you tried doing your javascript in a separate file so that it can
> be parsed w/ a JS editor, rather than a PHP editor?
I have pure Javascript functions in a separate file, but it happens to
be that 65% of this function is generated from PHP variables, so I am
outputting it inline.
Micah
FUDForum. Page generated in 0.05120 seconds
