Home » Archived » BIRT » Nested lists advice
Nested lists advice [message #89401] Wed, 09 November 2005 15:21 Go to next message
Originally posted by: mlorenz.nc.rr.com
I have a report working for one list (via scripted datasource). What I
need to move to now is a list within a list. I.e. I have steps that each
have results. The results for one step are coming out fine in a list
currently. I need to add an iterator for the steps (and the results
within each).
I need advice from someone on the best way to do this. E.g., is it OK to
nest a palette List within another List? Is it easier to handle this some
other way (perhaps through another scripted result set)?
Any help would be greatly appreciated.
Mark
Re: Nested lists advice [message #90383 is a reply to message #89401] Fri, 11 November 2005 19:53 Go to previous message
Have you looked at the tutorial in BIRT Developer Guide->Field Guide to
BIRT->Building a report with parallel subreports? This design may be a
little more complex than your requirements, but it should show the
techniques you need.
Jane Tatchell
BIRT documentation lead
"Mark Lorenz" <mlorenz@nc.rr.com> wrote in message
news:a9f1872097c86698922428f6675205df$1@www.eclipse.org...
> within each).
> Mark
Previous Topic:BIRT Report Designer log file location
Next Topic:datasource password
Current Time: Mon Oct 27 04:01:43 EDT 2025
Powered by FUDForum. Page generated in 0.03398 seconds
