Home » Archived » BIRT » Metadata for dataset creation
Metadata for dataset creation [message #88695] Tue, 08 November 2005 09:19 Go to next message
Originally posted by: phazzard.xxxxxxxx.com
Hello all;
Is there any way to "turn off" the gathering of available tables, views,
and columns when one goes to edit a data set? We will most often be using
stored procs and SQL generated from other sources to define data sets and
don;t wish to incur the overhead of gathering this data.
Any help appreciated.
Pete H
Re: Metadata for dataset creation [message #89030 is a reply to message #88695] Tue, 08 November 2005 21:49 Go to previous messageGo to next message
Pete,
I assume using the Data Set filter is to late for what you are wanting.
I think the list is repopulated everytime you open the data set, and without
changing the source code I dont see a way of doing this.
Might be a good idea to put this in Bugzilla as an enhancement request.
Jason Weathersby
BIRT PMC
"Pete H" <phazzard@xxxxxxxx.com> wrote in message
news:d47078cab260662e73c4308dc462af85$1@www.eclipse.org...
> Hello all;
> Pete H
Re: Metadata for dataset creation [message #89312 is a reply to message #89030] Wed, 09 November 2005 13:17 Go to previous message
Thanks Jason;
Your assumption is correct. I would like for the metadata request to be
configurable i.e. available as an option for the developer to "turn on"
and "turn off". I'll make an enhancement request. Thanks!
Pete H
Jason Weathersby wrote:
> Pete,
> Jason Weathersby
> BIRT PMC
>> Hello all;
>> Pete H
Previous Topic:"dynamic table selection"
Next Topic:how to set parameter values via BIRT API
Current Time: Sun Oct 26 11:18:16 EDT 2025
Powered by FUDForum. Page generated in 0.04282 seconds
