| Exception (org.eclipse.jem.internal.proxy.initParser.Static.evaluate) [message #88644] |
Tue, 26 April 2005 07:18   |
Eclipse User  |
Hello Rich,
I think is is better to start a new thread concerning the exception.
And I see that you are right concerning my exception. The cause for it is
possibly my init string of my custom MyJLabel.
I would be so glad to get an explanation how to avoid the exception :-).
Here is the .xmi for my component:
<expression
xsi:type=" org.eclipse.jem.internal.instantiation:PTClassInstanceCreati on "
type="mycomponents.MyJLabel">
<arguments
xsi:type="org.eclipse.jem.internal.instantiation:PTStringLiteral "
literalValue = "Appl_de_DE"/>
<arguments
literalValue = "IDENTS_tt"/>
</expression>
Here is a code that will be generated:
private MyJLabel getMyJLabel() {
    if (myJLabel == null) {
        myJLabel = new MyJLabel ("Appl_de_DE", "IDENTS_tt");
    return myJLabel;
The class MyJLabel:
public class MyJLabel extends OurJLabel
public MyJLabel() {
    super();
public MyJLabel(String resourceName, String resourceKey) {
    super();
    setText(TextManager.getString(resourceName, resourceKey));
There will be only the font for the label set in the class OurJLabel.
And here is the exception:
!ENTRY org.eclipse.jem.proxy 2 0 Apr 26, 2005 12:47:54.860
!MESSAGE java.lang.RuntimeException
 org.eclipse.jem.internal.proxy.initParser.Static.evaluate(St atic.java:123)
 org.eclipse.jem.internal.proxy.initParser.InitializationStri ngParser.evaluate(InitializationStringParser.java:157)
 org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:239)
 org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n(ConnectionThread.java:47)
!ENTRY org.eclipse.ve.java.core 2 0 Apr 26, 2005 12:47:54.870
!MESSAGE
+++ Warning +++: Tue Apr 26 12:47:54 CEST 2005    Unable to create
enumeration value for SwingConstants.TOP
!MESSAGE Exception thrown.
!STACK 0
java.lang.InstantiationException: IWAV0125E "SwingConstants.TOP" is too
complicated to be evaluated
 org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.createBeanProxy(REMStandardBeanProxyFactory.java:262)
 org.eclipse.jem.internal.proxy.remote.REMAbstractBeanTypePro xy.newInstance(REMAbstractBeanTypeProxy.java:323)
 org.eclipse.jem.internal.proxy.remote.REMIntegerTypeBeanType Proxy.newInstance(REMIntegerTypeBeanTypeProxy.java:103)
 org.eclipse.ve.internal.java.core.EnumeratedLabelProvider.ge tEnumeratedValues(EnumeratedLabelProvider.java:51)
 org.eclipse.ve.internal.java.core.EnumeratedLabelProvider.ge tText(EnumeratedLabelProvider.java:91)
 org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.getValueAsString(AbstractPropertySheetEntry.java:722)
 org.eclipse.ui.views.properties.PropertySheetViewer.updateEn try(PropertySheetViewer.java:1123)
 org.eclipse.ui.views.properties.PropertySheetViewer.createIt em(PropertySheetViewer.java:346)
 org.eclipse.ui.views.properties.PropertySheetViewer.updateCh ildrenOf(PropertySheetViewer.java:1078)
 org.eclipse.ui.views.properties.PropertySheetViewer.access$2 (PropertySheetViewer.java:999)
 org.eclipse.ui.views.properties.PropertySheetViewer$2.childE ntriesChanged(PropertySheetViewer.java:298)
 org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.fireChildEntriesChanged(AbstractPropertySheetEntry.java :373)
 org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshChildEntries(AbstractPropertySheetEntry.java:831 )
 org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.setValues(AbstractPropertySheetEntry.java:1013)
 org.eclipse.ui.views.properties.PropertySheetViewer.setInput (PropertySheetViewer.java:805)
 org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged(PropertySheetPage.java:370)
 org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.superSelectionChanged(EToolsPropertySheetPage.java:254)
 org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.access$2(EToolsPropertySheetPage.java:247)
 org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e$1.run(EToolsPropertySheetPage.java:240)
	at  org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
 org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:106)
	at  org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2749)
	at  org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2434)
	at  org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
	at  org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
 org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
	at  org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
	at  org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
 org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
 org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
 org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
	at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
	at org.eclipse.core.launcher.Main.run(Main.java:704)
	at org.eclipse.core.launcher.Main.main(Main.java:688)
Thank you in advance
Elena
| Re: Exception (org.eclipse.jem.internal.proxy.initParser.Static.evaluate) [message #88865 is a reply to message #88792] |
Thu, 28 April 2005 02:25    |
Eclipse User  |
Hello Rich,
here is the configuration:
*** Date: 28.04.05 08:30
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M200409161125
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
C:\Programme\ExtendEclipse\eclipse\eclipse.exe -showsplash 600
-exitdata
C:\Programme\ExtendEclipse\eclipse\eclipse.exe -exitdata 8fc_58
-vm
C:\WINDOWS\system32\javaw.exe
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1114669716936
eclipse.vm=C:\WINDOWS\system32\javaw.exe
eclipse.vmargs=-cp
C:\Programme\ExtendEclipse\eclipse\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
 java.class.path=C:\Programme\ExtendEclipse\eclipse\startup.j ar
java.class.version=48.0
 java.endorsed.dirs=C:\Programme\Java\j2re1.4.2_07\lib\endors ed
java.ext.dirs=C:\Programme\Java\j2re1.4.2_07\lib\ext
java.home=C:\Programme\Java\j2re1.4.2_07
java.io.tmpdir=C:\DOKUME~1\odemeter\LOKALE~1\Temp\
 java.library.path=C:\WINDOWS\system32;.;C:\WINDOWS\system32; C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System3 2\Wbem;;C:\Programme\STI\bin\pc-win95
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.4.2_07-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.4
 java.util.prefs.PreferencesFactory=java.util.prefs.WindowsPr eferencesFactory
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.4.2_07
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.4.2_07-b05
line.separator=
org.eclipse.jdt.debug.ui.scrapbookActive=false
org.osgi.framework.executionenvironment=
org.osgi.framework.language=de
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.2.0
org.xml.sax.driver=org.apache.crimson.parser.XMLReaderImpl
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
osgi.bundles.defaultStartLevel=4
 osgi.bundlestore=c:\Programme\ExtendEclipse\eclipse\configur ation\org.eclipse.osgi\bundles
 osgi.configuration.area=file:/c:/Programme/ExtendEclipse/ecl ipse/configuration/
 osgi.framework=file:/c:/Programme/ExtendEclipse/eclipse/plug ins/org.eclipse.osgi_3.0.1/
osgi.framework.beginningstartlevel=1
osgi.framework.version=3.0.0
osgi.frameworkClassPath=core.jar, console.jar, osgi.jar, resolver.jar,
defaultAdaptor.jar, eclipseAdaptor.jar
osgi.install.area=file:/c:/Programme/ExtendEclipse/eclipse/
 osgi.instance.area=file:/C:/Programme/ExtendEclipse/eclipse/ workspace/
 osgi.logfile=C:\Programme\ExtendEclipse\eclipse\workspace\.m etadata\.log
 osgi.manifest.cache=c:\Programme\ExtendEclipse\eclipse\confi guration\org.eclipse.osgi\manifests
osgi.nl=de_DE
osgi.os=win32
 osgi.splashLocation=c:\Programme\ExtendEclipse\eclipse\plugi ns\org.eclipse.platform_3.0.1\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
 sun.boot.class.path=C:\Programme\Java\j2re1.4.2_07\lib\rt.ja r;C:\Programme\Java\j2re1.4.2_07\lib\i18n.jar;C:\Programme\J ava\j2re1.4.2_07\lib\sunrsasign.jar;C:\Programme\Java\j2re1. 4.2_07\lib\jsse.jar;C:\Programme\Java\j2re1.4.2_07\lib\jce.j ar;C:\Programme\Java\j2re1.4.2_07\lib\charsets.jar;C:\Progra mme\Java\j2re1.4.2_07\classes
sun.boot.library.path=C:\Programme\Java\j2re1.4.2_07\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium i486 i386
sun.io.unicode.encoding=UnicodeLittle
sun.java2d.fontpath=
sun.os.patch.level=Service Pack 2
user.country=DE
user.dir=C:\Programme\ExtendEclipse\eclipse
user.home=C:\Dokumente und Einstellungen\odemeter
user.language=de
user.name=odemeter
user.timezone=Europe/Berlin
user.variant=
vendor=Apache Software Foundation
vendor-url=http://xml.apache.org/xalan-j
version=2.4.1
*** Features:
org.eclipse.emf (2.0.1) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.doc (2.0.1) "Eclipse Modeling Framework (EMF) Programmers
Guide"
org.eclipse.emf.ecore.sdo (2.0.1) "EMF Service Data Objects (SDO)"
org.eclipse.emf.ecore.sdo.doc (2.0.0) "EMF Service Data Objects (SDO)
Programmers Guide"
org.eclipse.emf.ecore.sdo.source (2.0.1) "EMF Service Data Objects (SDO)
Source"
org.eclipse.emf.source (2.0.1) "Eclipse Modeling Framework (EMF) Source"
org.eclipse.gef (3.0.1) "Graphical Editing Framework"
org.eclipse.gef.sdk (3.0.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.gef.source (3.0.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.jdt (3.0.1) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.0.1) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.0.2) "Java EMF Model"
org.eclipse.jem.sdk (1.0.2) "Java EMF Model SDK"
org.eclipse.jem.source (1.0.2) "Java EMF Model Source"
org.eclipse.pde (3.0.1) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.0.1) "Eclipse Plug-in Development Environment
Developer Resources"
org.eclipse.platform (3.0.1) "Eclipse Platform"
org.eclipse.platform.source (3.0.1) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.sdk (3.0.1) "Eclipse Project SDK"
org.eclipse.ve (1.0.2) "Visual Editor"
org.eclipse.ve.sdk (1.0.2) "Visual Editor SDK"
org.eclipse.ve.source (1.0.2) "Visual Editor Source"
org.eclipse.xsd (2.0.1) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.0.0) "XML Schema Infoset Model (XSD) Programmers
Guide"
org.eclipse.xsd.source (2.0.1) "XML Schema Infoset Model (XSD) Source"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.1) "Event Model"
com.ibm.wtp.common.util (1.0.1) "Logging Plug-in"
com.ibm.wtp.emf.workbench (1.0.1.1) "EMF Workbench"
jadclipse (2.0.6) "jadclipse Plugin"
org.apache.ant (1.6.2) "Apache Ant"
org.apache.lucene (1.3.1) "Apache Lucene"
org.eclipse.ant.core (3.0.0) "Ant Build Tool Core"
org.eclipse.ant.ui (3.0.1) "Ant UI"
org.eclipse.compare (3.0.0) "Compare Support"
org.eclipse.core.boot (3.0.0) "Core Boot"
org.eclipse.core.expressions (3.0.0) "Expression Language"
org.eclipse.core.filebuffers (3.0.1) "File Buffers"
org.eclipse.core.resources (3.0.1) "Core Resource Management"
org.eclipse.core.resources.win32 (3.0.0) "Core Resource Management Win32
Fragment"
org.eclipse.core.runtime (3.0.1) "Core Runtime"
org.eclipse.core.runtime.compatibility (3.0.0) "Core Runtime Plug-in
Compatibility"
org.eclipse.core.variables (3.0.0) "Core Variables"
org.eclipse.debug.core (3.0.1) "Debug Core"
org.eclipse.debug.ui (3.0.1) "Debug UI"
org.eclipse.draw2d (3.0.1) "Draw2d"
org.eclipse.draw2d.doc.isv (3.0.1) "Draw2D Documentation"
org.eclipse.emf.codegen (2.0.1) "EMF Template Code Generator"
org.eclipse.emf.codegen.ecore (2.0.1) "EMF Ecore Code Generation"
org.eclipse.emf.codegen.ecore.ui (2.0.1) "EMF Ecore Code Generation UI"
org.eclipse.emf.codegen.ui (2.0.0) "EMF Template Code Generator UI"
org.eclipse.emf.common (2.0.1) "EMF Common"
org.eclipse.emf.common.ui (2.0.1) "EMF Common UI"
org.eclipse.emf.commonj.sdo (2.0.0) "CommonJ SDO"
Guide"
org.eclipse.emf.ecore (2.0.1) "EMF Ecore"
org.eclipse.emf.ecore.change (2.0.1) "EMF Ecore Change Model"
org.eclipse.emf.ecore.change.edit (2.0.0) "EMF Ecore Change Edit Support"
org.eclipse.emf.ecore.edit (2.0.0) "EMF Ecore Edit Support"
org.eclipse.emf.ecore.editor (2.0.1) "Sample Ecore Editor"
Programmers Guide"
org.eclipse.emf.ecore.sdo.edit (2.0.0) "EMF Service Data Objects (SDO)
Edit Support"
org.eclipse.emf.ecore.sdo.editor (2.0.0) "EMF Service Data Objects (SDO)
Editor"
Source"
org.eclipse.emf.ecore.xmi (2.0.1) "EMF XMI"
org.eclipse.emf.edit (2.0.1) "EMF Edit"
org.eclipse.emf.edit.ui (2.0.1) "EMF Edit UI"
org.eclipse.emf.mapping (2.0.1) "EMF Mapping"
org.eclipse.emf.mapping.ecore2ecore (2.0.1) "Ecore to Ecore Mapping"
org.eclipse.emf.mapping.ecore2ecore.editor (2.0.1) "Ecore to Ecore Mapping
Editor"
org.eclipse.emf.mapping.ui (2.0.0) "EMF Mapping UI"
org.eclipse.emf.mapping.xsd2ecore (2.0.1) "XSD to Ecore Mapping"
org.eclipse.emf.mapping.xsd2ecore.editor (2.0.1) "XSD to Ecore Mapping
Editor"
org.eclipse.gef.doc.isv (3.0.1) "Graphical Editing Framework Documentation"
Resources"
org.eclipse.help (3.0.0) "Help System Core"
org.eclipse.help.appserver (3.0.0) "Help Application Server"
org.eclipse.help.base (3.0.1) "Help System Base"
org.eclipse.help.ide (3.0.0) "Help System IDE"
org.eclipse.help.ui (3.0.0) "Help System UI"
org.eclipse.help.webapp (3.0.1) "Help System Webapp"
org.eclipse.jdt.core (3.0.1) "Java Development Tools Core"
org.eclipse.jdt.debug (3.0.1) "JDI Debug Model"
org.eclipse.jdt.debug.ui (3.0.1) "JDI Debug UI"
org.eclipse.jdt.doc.isv (3.0.1) "Eclipse JDT Plug-in Developer Guide"
org.eclipse.jdt.doc.user (3.0.1) "Eclipse Java Development User Guide"
org.eclipse.jdt.junit (3.0.1) "Java Development Tools JUnit support"
org.eclipse.jdt.junit.runtime (3.0.0) "Java Development Tools JUnit
runtime support"
org.eclipse.jdt.launching (3.0.1) "Java Development Tools Launching
Support"
org.eclipse.jdt.ui (3.0.1) "Java Development Tools UI"
org.eclipse.jem.beaninfo (1.0.2) "Java EMF Model BeanInfo (Introspection)
Support"
org.eclipse.jem.proxy (1.0.2) "Java EMF Model Proxy Support"
org.eclipse.jem.sdk (1.0.1) "Java EMF Model SDK"
org.eclipse.jem.ui (1.0.1) "Java EMF Model UI"
org.eclipse.jem.workbench (1.0.2) "Java EMF Model Workbench Support"
org.eclipse.jface (3.0.0) "JFace"
org.eclipse.jface.text (3.0.1) "JFace Text"
org.eclipse.ltk.core.refactoring (3.0.1) "Refactoring Core"
org.eclipse.ltk.ui.refactoring (3.0.1) "Refactoring UI"
org.eclipse.osgi (3.0.1) "OSGi System Bundle"
org.eclipse.osgi.services (3.0.0) "OSGi Release 3 Services"
org.eclipse.osgi.util (3.0.0) "OSGi R3 Utility Classes"
org.eclipse.pde.build (3.0.1) "Plug-in Development Environment Build
Support"
org.eclipse.pde.core (3.0.1) "Plug-in Development Core"
org.eclipse.pde.doc.user (3.0.0) "Eclipse Plug-in Development User Guide"
org.eclipse.pde.junit.runtime (3.0.0) "PDE JUnit Plug-in Test"
org.eclipse.pde.runtime (3.0.1) "Plug-in Development Environment Runtime"
org.eclipse.pde.ui (3.0.1) "Plug-in Development UI"
org.eclipse.platform.doc.isv (3.0.1) "Eclipse Platform Plug-in Developer
Guide"
org.eclipse.platform.doc.user (3.0.1) "Eclipse Workbench User Guide"
Resources"
org.eclipse.platform.source.win32.win32.x86 (3.0.1) "Eclipse Platform
Plug-in Developer Resources"
org.eclipse.search (3.0.1) "Search Support"
org.eclipse.swt (3.0.1) "Standard Widget Toolkit"
org.eclipse.swt.win32 (3.0.1) "Standard Widget Toolkit for Windows"
org.eclipse.team.core (3.0.0) "Team Support Core"
org.eclipse.team.cvs.core (3.0.1) "CVS Team Provider Core"
org.eclipse.team.cvs.ssh (3.0.0) "CVS SSH Core"
org.eclipse.team.cvs.ssh2 (3.0.0) "CVS SSH2"
org.eclipse.team.cvs.ui (3.0.1) "CVS Team Provider UI"
org.eclipse.team.ui (3.0.1) "Team Support UI"
org.eclipse.text (3.0.1) "Text"
org.eclipse.tomcat (4.1.30) "Tomcat Wrapper"
org.eclipse.ui (3.0.1) "Eclipse UI"
org.eclipse.ui.cheatsheets (3.0.1) "Cheat Sheets"
org.eclipse.ui.console (3.0.0) "Console"
org.eclipse.ui.editors (3.0.1) "Default Text Editor"
org.eclipse.ui.externaltools (3.0.1) "External Tools"
org.eclipse.ui.forms (3.0.0) "Eclipse Forms"
org.eclipse.ui.ide (3.0.1) "Eclipse IDE UI"
org.eclipse.ui.intro (3.0.1) "Intro Plugin"
org.eclipse.ui.presentations.r21 (3.0.1) "R21 Presentation Plug-in"
org.eclipse.ui.views (3.0.0) "Views"
org.eclipse.ui.win32 (3.0.1) "Win32 fragment"
org.eclipse.ui.workbench (3.0.1) "Workbench"
org.eclipse.ui.workbench.compatibility (3.0.0) "Workbench Compatibility"
org.eclipse.ui.workbench.texteditor (3.0.1) "Text Editor Framework"
org.eclipse.update.configurator (3.0.0) "Install/Update Configurator"
org.eclipse.update.core (3.0.1) "Install/Update Core"
org.eclipse.update.core.win32 (3.0.0) "Install/Update Core for Windows"
org.eclipse.update.scheduler (3.0.0) "Automatic Updates Scheduler"
org.eclipse.update.ui (3.0.1) "Install/Update UI"
org.eclipse.ve (1.0.1) "Visual Editor"
org.eclipse.ve.cde (1.0.2) "Visual Editor Common Data Editor"
org.eclipse.ve.doc (1.0.1) "Visual Editor User Guide"
org.eclipse.ve.java.core (1.0.2) "Visual Editor Java Core"
org.eclipse.ve.jfc (1.0.2) "Visual Editor for Java Foundation Classes"
org.eclipse.ve.propertysheet (1.0.1) "Visual Editor PropertySheet"
org.eclipse.ve.sdk (1.0.1) "Visual Editor SDK"
org.eclipse.ve.swt (1.0.2) "Visual Editor for Standard Widget Toolkit"
Guide"
org.eclipse.xsd.edit (2.0.1) "XML Schema Edit Framework"
org.eclipse.xsd.editor (2.0.1) "XML Schema Editor"
org.eclipse.xsd.test (2.0.1) "XML Schema Infoset Model Test"
org.junit (3.8.1) "JUnit Testing Framework"
*** User Preferences:
#Thu Apr 28 08:30:08 CEST 2005
/instance/org.eclipse.ve.cde/CUSTOMIZELAYOUTWINDOW_X=223
 /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.org.eclipse.ve.java.core|org.eclipse.jdt.launchin g.JRE_CONTAINER= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<classpath>\r\n<classpathentry
kind\="lib"
path\="C\:/Programme/Java/j2re1.4.2_07/lib/rt.jar"/>\r\n<classpathentry
kind\="lib"
path\="C\:/Programme/Java/j2re1.4.2_07/lib/sunrsasign.jar"/ >\r\n<classpathentry
kind\="lib"
path\="C\:/Programme/Java/j2re1.4.2_07/lib/jsse.jar"/>\r\n <classpathentry
kind\="lib"
path\="C\:/Programme/Java/j2re1.4.2_07/lib/jce.jar"/>\r\n <classpathentry
kind\="lib"
path\="C\:/Programme/Java/j2re1.4.2_07/lib/charsets.jar"/>\r\n <classpathentry
kind\="lib"
path\="C\:/Programme/Java/j2re1.4.2_07/lib/ext/dnsns.jar"/ >\r\n<classpathentry
kind\="lib"
path\="C\:/Programme/Java/j2re1.4.2_07/lib/ext/ldapsec.jar"/ >\r\n<classpathentry
kind\="lib"
path\="C\:/Programme/Java/j2re1.4.2_07/lib/ext/localedata.jar "/>\r\n<classpathentry
kind\="lib"
path\="C\:/Programme/Java/j2re1.4.2_07/lib/ext/sunjce_provider.jar "/>\r\n</classpath>\r\n
 /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.org.eclipse.ve.swt|org.eclipse.jdt.launching.JRE_ CONTAINER= <?xml
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
@org.eclipse.debug.ui=3.0.1
 /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_new_line_before_finally_in_try_statement=insert
 /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<templates/>
 /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.org.eclipse.ve.example.customwidget|org.eclipse.j dt.launching.JRE_CONTAINER= <?xml
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
@org.eclipse.ui.ide=3.0.1
/instance/org.eclipse.help.base/dontConfirmShowAll=true
 /instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 1,0 "
defaultVMConnector\="">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="0" name\="j2re1.4.2_07" path\="C\:\\Programme\\Java\\j2re1.4.2_07"
javadocURL\="http\://java.sun.com/j2se/1.4.2/docs/api"/>\r\n</vmType>\r\n</vmSettings>\r\n
 /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.ExampleProject|edmcomponents.EdmContainer= <?xml
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/EdmPlugin/collec tions.jar "/>\r\n<classpathentry
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/EdmPlugin/jcfiel d400J.jar "/>\r\n<classpathentry
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/EdmPlugin/jctabl e450J.jar "/>\r\n<classpathentry
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/EdmPlugin/jsse.j ar "/>\r\n<classpathentry
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/EdmPlugin/swinga ll.jar "/>\r\n<classpathentry
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/EdmPlugin/treeta ble.jar "/>\r\n<classpathentry
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/EdmPlugin/util.j ar "/>\r\n<classpathentry
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/EdmPlugin/EDMGUI _COMP.jar "/>\r\n<classpathentry
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/EdmPlugin/EdmCom ponents.jar "/>\r\n</classpath>\r\n
 /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.brace_position_for_constructor_declaration=next_line
/instance/org.eclipse.ui.workbench/resourcetypes=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<editors>\r\n<info name\="*"
extension\="jpage">\r\n<editor
id\="org.eclipse.jdt.debug.ui.SnippetEditor"/>\r\n</info >\r\n<info
name\="*" extension\="xsd2ecore">\r\n<editor
id\=" org.eclipse.emf.mapping.xsd2ecore.presentation.XSD2EcoreEdit orID "/>\r\n</info>\r\n<info
name\="MANIFEST" extension\="MF">\r\n<editor
id\="org.eclipse.pde.ui.manifestEditor"/>\r\n</info>\r\n <info name\="*"
extension\="datagraph">\r\n<editor
id\="org.eclipse.emf.ecore.sdo.presentation.SDOEditorID"/>\r\n </info>\r\n<info
name\="build" extension\="properties">\r\n<editor
id\="org.eclipse.pde.ui.buildEditor"/>\r\n</info>\r\n<info name\="*"
extension\="ent">\r\n<editor
id\="org.eclipse.ant.ui.internal.editor.AntEditor"/>\r\n</info >\r\n<info
name\="*" extension\="xmi">\r\n<editor
id\="org.eclipse.emf.ecore.presentation.ReflectiveEditorID"/ >\r\n</info>\r\n<info
name\="*" extension\="jardesc">\r\n<editor
id\="org.eclipse.jdt.ui.JARDescEditor"/>\r\n</info>\r\n <info name\="*"
extension\="java">\r\n<editor
id\="org.eclipse.jdt.ui.CompilationUnitEditor"/>\r\n<editor
id\=" org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itor "/>\r\n</info>\r\n<info
name\="feature" extension\="xml">\r\n<editor
id\="org.eclipse.pde.ui.featureEditor"/>\r\n</info>\r\n <info name\="*"
extension\="class">\r\n<editor
id\="jadclipse.JadclipseClassFileEditor"/>\r\n<editor
id\="org.eclipse.jdt.ui.ClassFileEditor"/>\r\n</info>\r\n <info name\="*"
extension\="mxsd">\r\n<editor
id\="org.eclipse.pde.ui.schemaEditor"/>\r\n</info>\r\n<info name\="*"
extension\="genmodel">\r\n<editor
id\=" org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel EditorID "/>\r\n</info>\r\n<info
name\="*" extension\="exsd">\r\n<editor
extension\="override">\r\n<editor
id\="org.eclipse.jem.beaninfo.OverrideEditor"/>\r\n</info >\r\n<info
name\="*" extension\="ecore">\r\n<editor
id\="org.eclipse.emf.ecore.presentation.EcoreEditorID"/>\r\n </info>\r\n<info
name\="*" extension\="macrodef">\r\n<editor
name\="sample" extension\="properties">\r\n<editor
id\="org.eclipse.pde.ui.sampleEditor"/>\r\n</info>\r\n<info name\="plugin"
id\="org.eclipse.jdt.ui.DefaultTextEditor"/>\r\n</info>\r\n <info
name\="build" extension\="xml">\r\n<editor
name\="site" extension\="xml">\r\n<editor
id\="org.eclipse.pde.ui.siteEditor"/>\r\n</info>\r\n<info name\="*"
extension\="txt">\r\n<editor
id\="org.eclipse.ui.DefaultTextEditor"/>\r\n</info>\r\n <info
name\="fragment" extension\="xml">\r\n<editor
extension\="ecore2ecore">\r\n<editor
id\=" org.eclipse.emf.mapping.ecore2ecore.presentation.Ecore2Ecore EditorID "/>\r\n</info>\r\n<info
name\="*" extension\="xsd">\r\n<editor
id\="org.eclipse.xsd.presentation.XSDEditorID"/>\r\n</info >\r\n<info
name\="*" extension\="emof">\r\n<editor
id\="org.eclipse.emf.ecore.presentation.EcoreEditorID"/>\r\n </info>\r\n</editors>\r\n
@org.eclipse.pde.core=3.0.1
 /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.org.eclipse.ve.cde|org.eclipse.pde.core.requiredP lugins= <?xml
kind\="src" path\="/org.eclipse.ve.propertysheet"/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.emf. source_2.0.1/src/org.eclipse.emf.ecore.xmi_2.0.1/runtime/eco re.xmisrc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.emf. ecore.xmi_2.0.1/runtime/ecore.xmi.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.emf. source_2.0.1/src/org.eclipse.emf.ecore_2.0.1/runtime/ecoresr c.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.emf. ecore_2.0.1/runtime/ecore.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.emf. source_2.0.1/src/org.eclipse.emf.common_2.0.1/runtime/common src.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.emf. common_2.0.1/runtime/common.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.gef. source_3.0.1/src/org.eclipse.gef_3.0.1/gefsrc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.gef_ 3.0.1/gef.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.gef. source_3.0.1/src/org.eclipse.draw2d_3.0.1/draw2dsrc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.draw 2d_3.0.1/draw2d.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.plat form.source.win32.win32.x86_3.0.1/src/org.eclipse.swt.win32_ 3.0.1/ws/win32/swtsrc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.swt. win32_3.0.1/ws/win32/swt.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.plat form.source_3.0.1/src/org.eclipse.ui.views_3.0.0/viewssrc.zi p "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.ui.v iews_3.0.0/views.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.plat form.source_3.0.1/src/org.eclipse.ui.ide_3.0.1/idesrc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.ui.i de_3.0.1/ide.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.plat form.source_3.0.1/src/org.eclipse.core.resources_3.0.1/resou rcessrc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.core .resources_3.0.1/resources.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.plat form.source_3.0.1/src/org.eclipse.jface.text_3.0.1/jfacetext src.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.jfac e.text_3.0.1/jfacetext.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.plat form.source_3.0.1/src/org.eclipse.text_3.0.1/textsrc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.text _3.0.1/text.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.plat form.source_3.0.1/src/org.eclipse.jface_3.0.0/jfacesrc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.jfac e_3.0.0/jface.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.plat form.source_3.0.1/src/org.eclipse.ui.workbench_3.0.1/workben chsrc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.ui.w orkbench_3.0.1/workbench.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.plat form.source_3.0.1/src/org.eclipse.core.runtime_3.0.1/runtime src.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.core .runtime_3.0.1/runtime.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.plat form.source_3.0.1/src/org.eclipse.osgi_3.0.1/osgisrc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.osgi _3.0.1/osgi.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.plat form.source_3.0.1/src/org.eclipse.osgi_3.0.1/coresrc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.osgi _3.0.1/core.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.plat form.source_3.0.1/src/org.eclipse.osgi_3.0.1/resolversrc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.osgi _3.0.1/resolver.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.plat form.source_3.0.1/src/org.eclipse.osgi_3.0.1/defaultAdaptors rc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.osgi _3.0.1/defaultAdaptor.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.plat form.source_3.0.1/src/org.eclipse.osgi_3.0.1/eclipseAdaptors rc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.osgi _3.0.1/eclipseAdaptor.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.plat form.source_3.0.1/src/org.eclipse.osgi_3.0.1/consolesrc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.osgi _3.0.1/console.jar "/>\r\n</classpath>\r\n
 /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.blank_lines_before_field=0
 /instance/org.eclipse.ve.java.core/VISUAL_CLASS_WIZARD_SELEC TED_ELEMENT_KEY=org.eclipse.ve.jfc.swing.cat-Panel-javax.swi ng.JPanel
 /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.code_te mplates_migrated=true
@jadclipse=2.0.6
 /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.org.eclipse.ve.propertysheet|org.eclipse.pde.core .requiredPlugins= <?xml
kind\="lib"
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.plat form.source_3.0.1/src/org.eclipse.ui_3.0.1/uisrc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.ui_3 .0.1/ui.jar "/>\r\n<classpathentry
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
 /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.ExampleProject|SWT_CONTAINER= <?xml
sourcepath\=" /c\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.pla tform.source.win32.win32.x86_3.0.1/src/org.eclipse.swt.win32 _3.0.1/ws/win32/swtsrc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.swt. win32_3.0.1/ws/win32/swt.jar "/>\r\n</classpath>\r\n
 /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.EdmPlugin_1.1|org.eclipse.pde.core.requiredPlugin s= <?xml
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.osgi _3.0.1/console.jar "/>\r\n<classpathentry
kind\="src" path\="/org.eclipse.ve.cde"/>\r\n<classpathentry kind\="src"
path\="/org.eclipse.ve.java.core"/>\r\n<classpathentry kind\="src"
path\="/org.eclipse.ve.jfc"/>\r\n<classpathentry kind\="src"
path\="/org.eclipse.ve.propertysheet"/>\r\n<classpathentry kind\="src"
path\="/org.eclipse.ve.swt"/>\r\n<classpathentry kind\="src"
path\="/org.eclipse.jem"/>\r\n<classpathentry kind\="src"
path\="/org.eclipse.jem.beaninfo"/>\r\n<classpathentry kind\="src"
path\="/org.eclipse.jem.proxy"/>\r\n<classpathentry kind\="src"
path\="/org.eclipse.jem.ui"/>\r\n<classpathentry kind\="src"
path\="/org.eclipse.jem.workbench"/>\r\n<classpathentry
kind\="lib"
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.emf. common_2.0.1/runtime/common.jar "/>\r\n</classpath>\r\n
@org.eclipse.ve.cde=1.0.2
 /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_throws_clause_in_constructor_declaration=0
 /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.EdmPlugin_alt|org.eclipse.jdt.launching.JRE_CONTA INER= <?xml
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
@org.eclipse.jdt.ui=3.0.1
 /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.org.eclipse.jem.proxy|org.eclipse.pde.core.requir edPlugins= <?xml
kind\="lib"
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.jdt. source_3.0.1/src/org.eclipse.jdt.launching_3.0.1/launchingsr c.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.jdt. launching_3.0.1/launching.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.jdt. source_3.0.1/src/org.eclipse.jdt.core_3.0.1/jdtcoresrc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.jdt. core_3.0.1/jdtcore.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.plat form.source_3.0.1/src/org.eclipse.debug.core_3.0.1/dtcoresrc .zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.debu g.core_3.0.1/dtcore.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/com.ibm.wtp.comm on.util_1.0.1/utilsrc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/com.ibm.wtp.comm on.util_1.0.1/util.jar "/>\r\n<classpathentry
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.pde. source_3.0.1/src/org.eclipse.pde.core_3.0.1/pdecoresrc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.pde. core_3.0.1/pdecore.jar "/>\r\n<classpathentry
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.ui.w orkbench_3.0.1/workbench.jar "/>\r\n</classpath>\r\n
 /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.EdmPlugin_1.0|org.eclipse.jdt.launching.JRE_CONTA INER= <?xml
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
@org.eclipse.core.resources=3.0.1
 /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.org.eclipse.jem.ui|org.eclipse.pde.core.requiredP lugins= <?xml
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.jdt. source_3.0.1/src/org.eclipse.jdt.ui_3.0.1/jdtsrc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.jdt. ui_3.0.1/jdt.jar "/>\r\n<classpathentry
kind\="src" path\="/org.eclipse.jem.beaninfo"/>\r\n<classpathentry
kind\="lib"
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.plat form.source_3.0.1/src/org.eclipse.debug.ui_3.0.1/dtuisrc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.debu g.ui_3.0.1/dtui.jar "/>\r\n<classpathentry
kind\="lib"
kind\="src" path\="/org.eclipse.jem.proxy"/>\r\n<classpathentry
kind\="lib"
sourcepath\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.jdt. source_3.0.1/src/org.eclipse.jdt.debug.ui_3.0.1/jdiuisrc.zip "
kind\="lib"
path\=" C\:/Programme/ExtendEclipse/eclipse/plugins/org.eclipse.jdt. debug.ui_3.0.1/jdiui.jar "/>\r\n<classpathentry
kind\="lib"
kind\="src" path\="/org.eclipse.jem.workbench"/>\r\n<classpathentry
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
path\="
| Re: Exception (org.eclipse.jem.internal.proxy.initParser.Static.evaluate) [message #607252 is a reply to message #88721] |
Tue, 26 April 2005 13:57   |
Eclipse User  |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
I'm stumped. The only place it can come from is BeanInfo, and our
BeanInfo doesn't use an unqualified SwingConstants. It uses
"javax.swing.SwingConstants", and this is not what your message is
saying. There is something different about your system and I have no
idea what. No one else is getting this either.
What java version are you using?
Rich Kulp
| Re: Exception (org.eclipse.jem.internal.proxy.initParser.Static.evaluate) [message #607255 is a reply to message #88763] |
Wed, 27 April 2005 10:40   |
Eclipse User  |
I tried the VE at another pc without my customized components.
The versions of all software were the same and I got the same exception,
see below.
Elena
!ENTRY org.eclipse.jem.proxy 2 0 Apr 27, 2005 14:41:20.573
!ENTRY org.eclipse.ve.java.core 2 0 Apr 27, 2005 14:41:20.583
!MESSAGE
+++ Warning +++: Wed Apr 27 14:41:20 CEST 2005    Unable to create
enumeration value for SwingConstants.LEFT
!STACK 0
java.lang.InstantiationException: IWAV0125E "SwingConstants.LEFT" is too
 org.eclipse.ui.views.properties.PropertySheetViewer.access$4 (PropertySheetViewer.java:1117)
 org.eclipse.ui.views.properties.PropertySheetViewer$2.valueC hanged(PropertySheetViewer.java:309)
 org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.fireValueChanged(AbstractPropertySheetEntry.java:399)
 org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.setValues(AbstractPropertySheetEntry.java:1016)
 org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshValues(AbstractPropertySheetEntry.java:877)
 org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshChildEntries(AbstractPropertySheetEntry.java:808 )
	at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
	at org.eclipse.core.launcher.Main.run(Main.java:644)
	at org.eclipse.core.launcher.Main.main(Main.java:628)
| Re: Exception (org.eclipse.jem.internal.proxy.initParser.Static.evaluate) [message #607256 is a reply to message #88779] |
Wed, 27 April 2005 11:34   |
Eclipse User  |
I just did a clean install of Eclipse SDK 3.0.2, GEF 3.0.1, EMF 2.0.1,
VE 1.0.2. Created a brand new empty workspace and then a project.
Created a subclass of JPanel and dropped a JLabel on the content pane. I
get no errors.
Please go to Help->About Eclipse->Configuration Details. From that
dialog, please do a copy and paste it into this newsgroup so that I can
see your entire configuration. That may tell me if something else is in
there that could be causing a problem.
Rich Kulp
| Re: Exception (org.eclipse.jem.internal.proxy.initParser.Static.evaluate) [message #607260 is a reply to message #88792] |
Eclipse User  |
Hello Rich,
win32
-ws
win32
-arch
x86
-showsplash
-exitdata
-vm
eclipse.vmargs=-cp
eof=eof
file.separator=\
line.separator=
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.nl=de_DE
osgi.os=win32
osgi.ws=win32
path.separator=;
user.country=DE
user.language=de
user.name=odemeter
user.variant=
version=2.4.1
*** Features:
Guide"
Programmers Guide"
Source"
Resources"
Resources"
Resources"
Guide"
Fragment"
Compatibility"
Guide"
Programmers Guide"
Edit Support"
Editor"
Source"
Editor"
Editor"
Resources"
runtime support"
Support"
Support"
Support"
Guide"
Resources"
Guide"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
@jadclipse=2.0.6
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
path\="
| Re: Exception (org.eclipse.jem.internal.proxy.initParser.Static.evaluate) [message #607263 is a reply to message #88865] |
Thu, 28 April 2005 10:23   |
Eclipse User  |
What you are getting should be impossible unless one of two things:
1) The BeanInfo jar has been replaced and is not the one we shipped.
2) There is a JLabelBeanInfo class somewhere in the classpath of the
project.
So please look at the timestamp and size of this file:
 c:\Programme\ExtendEclipse\eclipse\plugins\org.eclipse.ve.jf c_1.0.2\vm\jfcbeaninfo.jar
It should be dated Dec. 9, 2004 2:06 PM and size should be 552KB
And make sure there are no BeanInfo classes anywhere in the classpath of
the project.
Rich Kulp
| Re: Exception (org.eclipse.jem.internal.proxy.initParser.Static.evaluate) [message #607265 is a reply to message #88910] |
Thu, 28 April 2005 11:23   |
Eclipse User  |
Hello Rich,
I can understand you if you do not believe me.
But I do not have any beaninfo classes and the jfcbeaninfo.jar has exactly
the timestamp and the size as you are saying.
As I got the exception at another pc. It was the pc of my colleage. It
means I did not install the software there. And he got the same exception.
We can end the discussion here concerning this theme. I do not want to
stress you. You are not here and you cannot see the exception. I wish you
to be succesfully at your work. I seem just to have bad luck.
Elena
| Re: Exception (org.eclipse.jem.internal.proxy.initParser.Static.evaluate) [message #607362 is a reply to message #88952] |
Sun, 08 May 2005 12:41   |
Eclipse User  |
Found the problem. Someone else was getting something similiar and I
tracked it down. You must have Sun's dt.jar somewhere in your classpath.
  This jar provides Sun's version of the BeanInfo for Swing, and it
conflicts with our version.
You'll need to remove it and run a clean build for all projects.
The problem is they are using the same name and format for providing
enumeration values but they break the standard rule in BeanInfo in that
they don't fully-qualify the init strings.
Rich Kulp wrote:
> I'm just plain lost on this. I have the actual code sitting right in
> front me and I don't see how it could go from
> "javax.swing.SwingConstants.TOP" to just "SwingConstants.TOP". The
> BeanInfo just doesn't decide to strip off the package like that.
> Sorry, I wish I could help you.
Rich Kulp
| Re: Exception (org.eclipse.jem.internal.proxy.initParser.Static.evaluate) [message #607379 is a reply to message #90089] |
Tue, 10 May 2005 05:20   |
Eclipse User  |
I deleted the file "dt.jar" in "C:/j2sdk1.4_2.07/lib" and executed
"Project | Clean". And I do not get any exception in Eclipse-workbench.
But if I start a new workbench (with option -clean) in this workbench to
test my plugin I get the same exception as in the past. I also did
"Project | Clean" in the test workbench.
Could you give me a hint what you meant with "clean your projects".
Have I forgotten something ?
Elena
