Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Import XMI
Import XMI [message #88448] Fri, 06 July 2007 10:59 Go to next message
Originally posted by: kevin.m.meredith.lmco.com
I would like to import XMI to Eclipse, specifically RSA, however this
error appears when attempting to load it via Java code.
Package with uri 'http://schema.omg.org/spec/UML/2.1.1' not found
I believe that the project being created via Java is a Java project, not
the desired UML project.
Please help me to specify that my Java code will specify that a UML model
is to be created.
Here's my code:
* Main.java
* Created on July 5, 2007, 3:37 PM
* To change this template, choose Tools | Template Manager
* and open the template in the editor.
package loadxmi;
import java.io.File;
import java.io.IOException;
//import java.net.URI;
import org.eclipse.emf.common.util.URI;
import java.util.Collections;
//import org.eclipse.emf.*;
import org.eclipse.emf.ecore.resource.*;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl;
import org.eclipse.emf.ecore.EAttribute;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.EReference;
* @author mereditk
public class Main {
/** Creates a new instance of Main */
public Main() {
* @param args the command line arguments
// Create a resource set.
ResourceSet resourceSet = new ResourceSetImpl();
// Register the default resource factory -- only needed for
stand-alone!
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(
Resource.Factory.Registry.DEFAULT_EXTENSION, new
XMIResourceFactoryImpl());
// Register the package -- only needed for stand-alone!
//LibraryPackage libraryPackage = LibraryPackage.eINSTANCE;
// Get the URI of the model file.
//URI fileURI = URI.createFileURI(new File("c:/documents and
settings/mereditk/desktop/jfacc.xmi").getAbsolutePath());
File("e:/tif/KevinMeredith/Samples/xmi/UPDM
Example.xmi").getAbsolutePath());
URI fileURI = URI.createFileURI(new File("C:/Documents and
Settings/mereditk/Desktop/abc2.xmi").getAbsolutePath());
// Demand load the resource for this file.
Resource resource = resourceSet.getResource(fileURI, true);
// Print the contents of the resource to System.out.
try
resource.save(System.out, Collections.EMPTY_MAP);
catch (IOException e) {}
Re: Import XMI [message #88464 is a reply to message #88448] Fri, 06 July 2007 11:07 Go to previous messageGo to next message
Kevin,
Please use the UML2 newsgroup for questions about UML. I've added it to
the "to" list of the reply, so there's no need to repost the question.
I'm pretty sure they have migration documentation that describes how to
do this, so be sure to check out what's available:
http://wiki.eclipse.org/index.php/MDT-UML2
> not the desired UML project.
> model is to be created.
> Here's my code:
> * Main.java
> package loadxmi;
> * @author mereditk
> public class Main {
> public Main() {
> public static void main(String[] args) {
> stand-alone!
> try
Re: Import XMI [message #88479 is a reply to message #88464] Fri, 06 July 2007 11:13 Go to previous messageGo to next message
Mr. Merks,
I appreciate your swift replies, however I do not understand how the act
of importing an XMI file to Eclipse/Rational Software Architect does not
fall under Eclipse Modeling Framework.
Obviously your knowledge of Eclipse exceeds mine. Do you understand that
I'm attempting to import an XMI file to RSA using Java code? One recurring
error that I've encountered is, "Package with uri
'http://schema.omg.org/spec/UML/2.1.1' not found." I respectfully state so
because I am attempting a very simple task, so I hope that you're not
misinterpreting my simple objective and convoluting it.
I know that the XMI file can be imported to RSA, since I just did so
manually in RSA after I created a UML project, then used the Import
command for an XMI file.
Please help me to rephrase my question in the UML forum so that I can be
fully helped.
I continue to appreciate your help!
Kevin
Re: Import XMI [message #88494 is a reply to message #88479] Fri, 06 July 2007 11:30 Go to previous messageGo to next message
Kevin,
It seemed pretty clear you were trying to read an instance of a UML2
model given the package not found error involving the UML namespace. In
general, to read an XMI file you need an Ecore model for the type of
data in the file. I suspect you should be registering
XMI2UMLResource.Factory.INSTANCE...
Kevin M wrote:
> Mr. Merks,
> act of importing an XMI file to Eclipse/Rational Software Architect
> does not fall under Eclipse Modeling Framework.
> that I'm attempting to import an XMI file to RSA using Java code? One
> recurring error that I've encountered is, "Package with uri
> state so because I am attempting a very simple task, so I hope that
> you're not misinterpreting my simple objective and convoluting it.
> be fully helped.
> Kevin
Re: Import XMI [message #88521 is a reply to message #88494] Fri, 06 July 2007 13:52 Go to previous messageGo to next message
Mr. Merks, how would XMI2UMLResource.Factory.INSTANCE be registered with
respect to this code?
Should the XMIResource class be used? Please give a code snippet.
* Main.java
package loadxmi;
* @author mereditk
public class Main {
public Main() {
stand-alone!
try
Thanks!
Kevin
Re: Import XMI [message #88536 is a reply to message #88521] Fri, 06 July 2007 14:05 Go to previous messageGo to next message
Kevin,
I'm not expert at how to use UML2, but I assume you'd use
XMI2UMLResource.Factory.INSTANCE in place of "new
XMIResourceFactoryImpl()". There might be other setup things you need
to do, so best to look for documentation or wait until Kenn or James
provides more details.
> with respect to this code?
> * Main.java
> package loadxmi;
> * @author mereditk
> public class Main {
> public Main() {
> stand-alone!
> try
> Thanks!
> Kevin
Re: Import XMI [message #88687 is a reply to message #88536] Mon, 09 July 2007 11:54 Go to previous message
Hi Kevin,
I'm not sure if you had a look at the migration guide as Ed suggested?
There is some sample code there to load models ( look toward the end of the
document ).
It shows how to set up registration of extensions and packages.
You should be able to add an entry to registerExtensions() to do something
like ...
extensionFactoryMap.put(XMI2UMLResource.FILE_EXTENSION,
XMI2UMLResource.Factory.INSTANCE).
Have you tried that? Let me know if that works. If you are still having
issues, please post a sample xmi model and I'll give it a try.
- James.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:f6m098$ivr$1@build.eclipse.org...
> Kevin,
> > * Main.java
> > package loadxmi;
> > * @author mereditk
> > public class Main {
> > public Main() {
> > stand-alone!
> > try
> > Thanks!
> > Kevin
Re: Import XMI [message #608662 is a reply to message #88448] Fri, 06 July 2007 11:07 Go to previous message
Kevin,
> Here's my code:
> * Main.java
> package loadxmi;
> * @author mereditk
> public class Main {
> public Main() {
> stand-alone!
> try
Re: Import XMI [message #608663 is a reply to message #88464] Fri, 06 July 2007 11:13 Go to previous message
Mr. Merks,
fully helped.
Kevin
Re: Import XMI [message #608664 is a reply to message #88479] Fri, 06 July 2007 11:30 Go to previous message
Kevin,
Kevin M wrote:
> Mr. Merks,
> be fully helped.
> Kevin
Re: Import XMI [message #608666 is a reply to message #88494] Fri, 06 July 2007 13:52 Go to previous message
* Main.java
package loadxmi;
* @author mereditk
public class Main {
public Main() {
stand-alone!
try
Thanks!
Kevin
Re: Import XMI [message #608667 is a reply to message #88521] Fri, 06 July 2007 14:05 Go to previous message
Kevin,
> * Main.java
> package loadxmi;
> * @author mereditk
> public class Main {
> public Main() {
> stand-alone!
> try
> Thanks!
> Kevin
Re: Import XMI [message #608677 is a reply to message #88536] Mon, 09 July 2007 11:54 Go to previous message
Hi Kevin,
document ).
like ...
- James.
> Kevin,
> > * Main.java
> > package loadxmi;
> > * @author mereditk
> > public class Main {
> > public Main() {
> > stand-alone!
> > try
> > Thanks!
> > Kevin
Previous Topic:[Teneo / JPOX]
Next Topic:[EMF Compare] - Quick question wrt EMFDIFF format
Current Time: Tue Nov 04 09:43:50 EST 2025
Powered by FUDForum. Page generated in 0.07970 seconds
