Home » Eclipse Projects » Eclipse Platform » Emulate Windows combo (with graphics)
Emulate Windows combo (with graphics) [message #86663] Tue, 01 July 2003 14:39 Go to next message
Originally posted by: simon_miller.uk.ibm.mail
I'm trying to build a Windows style Combo box without success.
The requirement is to emulate the Windows drop down Combo box within an
Explorer window:
Start Explorer and right click on a folder and Open.
The Combo box shows the system Drives and where the user is.
This uses a combination of graphics and text. The same behaviour exsits
within the FileDialog however I have tyhe need to integrate the content of
the FileDialog within a Windows (not use the FileDialog).
Unless I have it all wrong this isn't an easy or lightweight task?
Simon
Re: Emulate Windows combo (with graphics) [message #87065 is a reply to message #86663] Tue, 01 July 2003 23:48 Go to previous message
Originally posted by: scheglov_ke.nlmk.ru
Simon Miller <simon_miller@uk.ibm.mail> wrote:
Yes, this is not easy task.
You should use CCombo as start point, copy it source to your
project and then replace List, used as drop down to Tree (or may
be your custom widget). Biggest problem is that CCombo uses Shell
to show popup, so when it receives focus, your main shell will lose
it, and caption will become inactive. This can baffle users...
> Explorer window:
> Simon
SY, Konstantin.
Previous Topic:Keys sets
Next Topic:new extension for java files...
Current Time: Fri Nov 07 14:38:33 EST 2025
Powered by FUDForum. Page generated in 0.03173 seconds
