Home » Archived » M2M (model-to-model transformation) » [ATL] Problems to migrate to Ganymede
[ATL] Problems to migrate to Ganymede [message #86620] Thu, 17 July 2008 03:52 Go to next message
Hi, I have a problem with AM3.
I have some ATL transformations that I execute with ANT scripts using AM3.
Now, we are migrating to Eclipse Ganymede and when I execute the
transformation an error appears:
INFO: Executing ATL transformation Transformations/uml2db.atl
C:\eclipses\Eclipse
Ganymede\workspace\es.cv.gvcase.linkers.uml2db.transf\bin\es
\cv\gvcase\linker\uml2db\transf\launcher
\build.xml:15:java.lang.NoSuchMethodError:
org.eclipse.m2m.atl.adt.launching.AtlVM.launch
If we have a look to error, we can see that in 15 line is the problem and
we realize that the error is in build.xml, exactly in:
<am3.atl path="Transformations/uml2db.atl"
allowInterModelReferences="true">
Could it be that am3 isn't compatible with new version of ATL ?¿?
what can I do ?¿?
thanks !!!
Re: [ATL] Problems to migrate to Ganymede [message #89351 is a reply to message #86620] Fri, 29 August 2008 04:52 Go to previous message
> AM3. Now, we are migrating to Eclipse Ganymede and when I execute the
> C:\eclipses\Eclipse
> and we realize that the error is in build.xml, exactly in:
> what can I do ?¿?
> thanks !!!
Perhaps... AM3's CVS code should however be compatible with the latest
ATL, so you may try to install it from CVS:
http://wiki.eclipse.org/AM3/How_Install_AM3_From_CVS
Dennis
Previous Topic:[ATL] AtlLauncher launch method
Next Topic:[ATL] Transformation in xmi format?
Current Time: Wed Nov 05 14:57:39 EST 2025
Powered by FUDForum. Page generated in 0.03386 seconds
