Home » Newcomers » Newcomers » 3.0.1 to 3.1 installation
3.0.1 to 3.1 installation [message #85906] Wed, 13 July 2005 04:34 Go to next message
Originally posted by: rue.romeral.de
I have 3.0.1 installed and want to upgrade to 3.1 because of Java 1.5
a) upgrade in eclipse only tells me about 3.0.2 (why not 3.1 ?)
b) downloading 3.1 leaves me with a lot of files and have to find out
where to put them, which takes some time. Is there any other way like an
istallation procedure ?
Re: 3.0.1 to 3.1 installation [message #85954 is a reply to message #85906] Wed, 13 July 2005 04:54 Go to previous messageGo to next message
> an istallation procedure ?
afaik the update servers aren't providing 3.1 yet. Easiest way to
upgrade for now is:
- download and unzip 3.1 into fresh location
- install all plug-ins which you installed for 3.0.2 (they should
continue to work)
- start it with -vm <vm location> -data <workspace loaction>
Dani
> Thanks
Re: 3.0.1 to 3.1 installation [message #86031 is a reply to message #85954] Wed, 13 July 2005 07:28 Go to previous messageGo to next message
Originally posted by: myersj.nospam.gmail.com
Daniel Megert wrote:
> rue wrote:
<snip>
continue to work)
I don't think most plug-ins for 3.0.x will run out of the box in 3.1.
Most plug-ins will have to be updated for api changes in 3.1.
- Jeff
Re: 3.0.1 to 3.1 installation [message #86256 is a reply to message #85906] Wed, 13 July 2005 12:31 Go to previous message
The automatic upgrade mechanism does not support major new releases like
going from 3.0 to 3.1 - you need to install it separately. See this wiki
page: http://eclipsewiki.editme.com/Upgrading
HTH,
Eric
Previous Topic:Can't use software updates feature
Next Topic:split pane?
Current Time: Sat Jul 19 10:21:04 EDT 2025
Powered by FUDForum. Page generated in 0.08328 seconds
