| Launching gdb on remote host [message #84458] |
Mon, 27 October 2003 16:15  |
Originally posted by: tclement.apcc.com
How can I launch a gdb session on remote target and debug locally
(&visually)using CDT Debug?
On the command line, I can type:
ssh -l user 159.215.65.209 gdb /home/user/hello/hello.elf
This opens a secure shell and launches gdb with my program.
At this point, gdb's output stream should be identical to one launched
locally,
but I can't get the CDT Debug UI to work this way.
DETAILS:
I am cross-compiling from a Win2K, Cygwin ix86-target GNU toolchain.
The target (NetBSD 1.6ZD on a i686) does not support GDB Server 5.3
or greater(yet), so I am trying to work-around by launching gdb locally,
and debugging remotely.
Ted
Theodore Clement
Staff Firmware Engineer
AEG Research & Development
American Power Conversion
132 Fairgrounds Road
W. Kingston, RI 02892
| Re: Launching gdb on remote host [message #84704 is a reply to message #84495] |
Tue, 28 October 2003 10:40  |
>Mikhail Khodjaiants wrote:
> But first try to run 'gdb -i mi1' on your target
I am able to run 'gdb -i mi1' on the target.
(gdb version is 5.3)
> Put 'ssh -l user 159.215.65.209 gdb' in the 'GDB
> Debugger' field. The CDT will add all parameters. I am not sure that this
> will work but give it a try.
I tried this statement in the GDB Debugger, Cygwin GDB Debugger and GDB
Server
fields, double-quoted, single-quoted and not quoted.
Each time, I get this error: "Failed Launching CDI Debugger: Error
creating session: Exec error:Launching failed"
DETAILS:
I am using Eclipse 2.1.1 with CDT 1.2.0 (on Windows 2000 host) and trying
to connect to a NetBSD 1.6ZD (ix86) target running gdb 5.3.
I also tried putting the line 'ssh -l user 159.215.65.209 gdb
myprogramname' in a DOS batch file (remote.bat) and using
"c:\winnt\system32\cmd.exe \C" in the GDB Debugger: field, and
"remote.bat" in the GDB Command File: field.
The CDT Debugger gives me the "Failed Launching CDI Debugger: Error
creating session: Exec error:Launching failed" error. The remote.bat file
executes correctly on the command line.
Ted
Theodore Clement
FUDForum. Page generated in 0.03549 seconds
