| Simple StandAlone BIRT Chart FAILS??? [message #80823] |
Thu, 13 October 2005 20:04  |
Originally posted by: jwalsh.santurcorp.com
Any info as to why simple "Hello Chart" fails and
throws:
java.lang.IllegalArgumentException: Source value can not be null
Code and Exception stack below.
Thanks.
public class BIRTChartTest implements PaintListener {
public BIRTChartTest() {
super();
System.setProperty("BIRT_HOME",
"C:/workspace/birt-charts-1_0_1");
BIRTChartTest bct = new BIRTChartTest();
Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
shell.setText("TestLineChart");
Canvas canvas = new Canvas(shell, SWT.NONE);
canvas.addPaintListener( bct );
shell.setSize(400, 400);
shell.open();
while (!shell.isDisposed())
if (!display.readAndDispatch()) display.sleep();
display.dispose();
public void paintControl(PaintEvent e) {
// let's get a SWT device renderer
IDeviceRenderer deviceRenderer = null;
try
System.setProperty("STANDALONE", "true");
deviceRenderer = PluginSettings.instance().getDevice("dv.SWT");
catch (Exception ex)
System.err.println(
"Oops, can't find the device renderer.");
ex.printStackTrace();
System.exit(1);
deviceRenderer.setProperty(IDeviceRenderer.GRAPHICS_CONTEXT, e.gc);
// now let's make sure we stay in the client area's bounds
Rectangle rect = ((Composite) e.widget).getClientArea();
final Bounds bounds = BoundsImpl.create(rect.x + 2,
rect.y + 2,
rect.width - 4,
rect.height - 4);
bounds.scale(72d /
deviceRenderer.getDisplayServer().getDpiResolution());
// create Rohit's chart
Chart chart = createSimpleLineChart();
// and finally, generate it...
final Generator gr = Generator.instance();
GeneratedChartState state;
try
state = gr.build(deviceRenderer.getDisplayServer(),
chart,
(Scriptable) null,
bounds,
new RunTimeContext());
gr.render(deviceRenderer, state);
System.exit(1);
public static final Chart createSimpleLineChart()
ChartWithAxes cwa = ChartWithAxesImpl.create();
cwa.getTitle().getLabel().getCaption().setValue("HelloChart ");
return cwa;
*** RESULTS IN:
org.eclipse.birt.chart.event.PrimitiveRenderEvent.setSourceO bject(PrimitiveRenderEvent.java:278)
org.eclipse.birt.chart.event.EventObjectCache.getEventObject (EventObjectCache.java:97)
org.eclipse.birt.chart.factory.RunTimeContext.notifyStructur eChange(RunTimeContext.java:157)
org.eclipse.birt.chart.render.AxesRenderer.renderPlot(AxesRe nderer.java:1771)
org.eclipse.birt.chart.render.AxesRenderer.render(AxesRender er.java:182)
at org.eclipse.birt.chart.factory.Generator.render(Generator.ja va:543)
at BIRTChartTest.paintControl(BIRTChartTest.java:133)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:844)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:868)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:853)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:11 53)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3089 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3682 )
at org.eclipse.swt.internal.win32.OS.UpdateWindow(Native Method)
at org.eclipse.swt.widgets.Decorations.setVisible(Decorations.j ava:1386)
at org.eclipse.swt.widgets.Shell.setVisible(Shell.java:1300)
at org.eclipse.swt.widgets.Shell.open(Shell.java:827)
at BIRTChartTest.main(BIRTChartTest.java:81)
Oct 13, 2005 4:36:48 PM org.eclipse.birt.chart.log.impl.JavaUtilLoggerImpl
log
SEVERE: Exception
org.eclipse.birt.chart.exception.ChartException: $NO-RB$ Source value can
not be null
at org.eclipse.birt.chart.factory.Generator.render(Generator.ja va:549)
Caused by: java.lang.IllegalArgumentException: Source value can not be null
... 14 more
not be null
... 14 more
| Re: Simple StandAlone BIRT Chart FAILS??? [message #82391 is a reply to message #80823] |
Wed, 19 October 2005 16:33  |
This looks like a bug, although a chart with only a title isn't very useful.
Can you file a bugzilla entry for it?
https://bugs.eclipse.org/bugs/enter_bug.cgi
David
"jwmeridian" <jwalsh@santurcorp.com> wrote in message
news:0b656ad8ece3d08c45722e704bcae22e$1@www.eclipse.org...
> throws:
> Thanks.
> super();
> public static void main(String[] args) {
> shell.open();
> display.dispose();
> try
> System.err.println(
> System.exit(1);
> rect.y + 2,
> rect.width - 4,
> rect.height - 4);
> bounds.scale(72d /
> try
> chart,
> (Scriptable) null,
> bounds,
> System.exit(1);
> return cwa;
> *** RESULTS IN:
> at
> at
> at
> at
> at
> at
> log
> SEVERE: Exception
> not be null
> at
> null
> at
> at
> at
> at
> at
> ... 14 more
> not be null
> at
> null
> at
> at
> at
> at
> at
> ... 14 more
FUDForum. Page generated in 0.04097 seconds
