Home » Archived » BIRT » Loading fonts when generating PDF
Loading fonts when generating PDF [message #80604] Thu, 13 October 2005 04:04 Go to next message
Originally posted by: coqueln.yahoo.fr
When I generate a document in PDF format
(options.setOutputFormat(HTMLRenderOption.OUTPUT_FORMAT_PDF) ;), Birt does
not seems to be able to load fonts.
I have the following error :
13 oct. 2005 09:55:10 org.apache.avalon.framework.logger.Jdk14Logger error
GRAVE: unknown font times new roman,normal,normal so defaulted font to any
I have no problem when I generate a HTML file.
Thanks in advance,
Nicolas
Re: Loading fonts when generating PDF [message #80838 is a reply to message #80604] Thu, 13 October 2005 23:40 Go to previous messageGo to next message
Originally posted by: jemmy_js.hotmail.com
i also encounter this problem,waiting for your solution!
"Nicolas Coquel" <coqueln@yahoo.fr> wrote in message
news:25e8c68d48937a76966c8aa44dd432f4$1@www.eclipse.org...
> I have the following error : 13 oct. 2005 09:55:10
> Thanks in advance,
> Nicolas
Re: Loading fonts when generating PDF [message #81574 is a reply to message #80604] Mon, 17 October 2005 15:19 Go to previous messageGo to next message
Originally posted by: eclipse.planetraven.de
Hi all,
i have the same problem (Fonts not found) when i try to generate a PDF
report using the report engine API.
Does anyone know a solution to this?
Bye,
David
Re: Loading fonts when generating PDF [message #83461 is a reply to message #80604] Mon, 24 October 2005 07:00 Go to previous message
Nicolas Coquel napisał(a):
> does not seems to be able to load fonts.
You have to configure fop.
Read this http://xmlgraphics.apache.org/fop/fonts.html
Previous Topic:How works run script?
Next Topic:Does interactivity work?
Current Time: Sat Nov 01 23:43:14 EDT 2025
Powered by FUDForum. Page generated in 0.03037 seconds
