| Compilation problems [message #78325] |
Thu, 19 June 2003 01:58  |
Originally posted by: lchen5.wisc.edu
I tried to compile a big project (around 50M of codes) and got the a lot of
warning and errors. But I can not see what the problem is, since the problem
windows shows
Problems(5,711 items)
There are too many items to display.
To see items in this window, adjust the filter settings.
I have tried to increase the maximum number of problems reported per
compliation unit to 20000 (at Window->Pereferences->Java->Compliler). But it
still does not work, does any one has any clue?
Lei
| Re: Compilation problems [message #78341 is a reply to message #78325] |
Thu, 19 June 2003 04:55  |
On Wed, 18 Jun 2003 22:58:43 -0700, Lei Chen <lchen5@wisc.edu> wrote:
To see all problems use "Filters..." toolbar button in the tasks view. It
will open dialog, that will let you to set number of displayed messages. If
you get such a huge number of problems you probably have to update
classpath of your projects first.
> of
> problem
> windows shows
> it
> Lei
best regards,
alexander kitaev
FUDForum. Page generated in 0.04389 seconds
