Home » Eclipse Projects » GEF » How to implement DND DROP_COPY in Outline
How to implement DND DROP_COPY in Outline [message #77116] Mon, 28 April 2003 13:06 Go to next message
Originally posted by: remko.popma.azzurri.jp
I'm looking for a way to do Drag & "Drop a Copy" in the Outline view of a
GEF editor.
I'm not sure if this is supported: pressing Ctrl while dragging gives the
correct feedback (the drag cursor
changes to a "plus" cursor), but dropping always results in a move, both in
the Logic example and
in my code.
Should I use TemplateTransferDropTargetListener?
I've tried adding a subclass of this class in configureOutlineViewer() (like
in the logic example):
getViewer().addDropTargetListener(new
MyTemplateTransferDropTargetListener(getViewer()));
but my listener never gets called.
I understand that if multiple drop listeners are registered, the
first one that understands the data type of the drop target event (as
determined by the
TransferDropTargetListener.isEnabled(DropTargetEvent) method) gets to handle
the drop.
Does this mean that I have to create a special data type if I want to enable
my handler?
Or should TemplateTransfer just work, and I missed something else?
(I have to admit that I don't understand the
ByteArrayTransfer.isSupportedType() implementation,
and if possible I would like to keep it that way :-)
Could anyone give me some pointers?
Thanks!
Remko Popma
Re: How to implement DND DROP_COPY in Outline [message #77131 is a reply to message #77116] Mon, 28 April 2003 13:15 Go to previous messageGo to next message
Copy on drag is not implemented yet in GEF. The fact that pressing CTRL key
does not result in the NOT cursor is a bug in GEF. We will fix this for the
2.1.1 release coming up.
You will either have to either:
1) copy TreeViewerTransfer, TreeViewerTransferDrag/DropListener, create your
own Request constant, etc. (and also wait for 2.1.1, since the current
TreeViewerDropListener will pre-empt your own listener and prevent it from
working during CTRL pressed)
OR
2) Submit these changes as patches for 2.1 (very soon) such that they might
get into 2.1.1.
OR
3) Wait for 2.2
"Remko Popma" <remko.popma@azzurri.jp> wrote in message
news:b8jn0m$9is$1@rogue.oti.com...
> GEF editor.
in
> in my code.
(like
> determined by the
handle
> the drop.
enable
> my handler?
> Thanks!
> Remko Popma
Re: How to implement DND DROP_COPY in Outline [message #77162 is a reply to message #77131] Mon, 28 April 2003 13:24 Go to previous messageGo to next message
Thank you for your reply. Very clear.
When is 2.1.1 scheduled to be released, and when is the deadline for
submitting 2.1.1 patches?
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b8jnjd$a1k$1@rogue.oti.com...
key
the
your
> OR
might
> get into 2.1.1.
> OR
> 3) Wait for 2.2
> > Hi,
a
> > GEF editor.
the
> in
> > in my code.
> (like
> > determined by the
> handle
> > the drop.
> enable
> > my handler?
> > Thanks!
> > Remko Popma
Re: How to implement DND DROP_COPY in Outline [message #77178 is a reply to message #77162] Mon, 28 April 2003 13:25 Go to previous message
news:b8jo2k$aho$1@rogue.oti.com...
End of June
Hopefully the end of this week
> key
> the
> your
from
> > OR
> might
> > get into 2.1.1.
> > OR
> > 3) Wait for 2.2
> > > Hi,
of
> a
> > > GEF editor.
> the
both
> > in
> > > in my code.
> > (like
> > > determined by the
> > handle
> > > the drop.
> > enable
> > > my handler?
> > > Thanks!
> > > Remko Popma
Previous Topic:DND issue
Next Topic:Where to start when creating a new GEF plugin?
Current Time: Sun Oct 19 21:17:47 EDT 2025
Powered by FUDForum. Page generated in 0.05086 seconds
