Home » Archived » BIRT » 3 values on X-axis
3 values on X-axis [message #76877] Fri, 23 September 2005 12:31 Go to next message
Originally posted by: Samuel.xxxx.com
Is there only 2 dimensional way of creation for Charts or can i do 3
dimensional too ?
I have to get three value bars on x-axis.Could you please give me an idea
how it is going to work? So far i only tried with one colum on x-axis. Now
i need to put three columns and should get three bars for each value
instead of one.
Immediate Help Apreciated.
Sam
Re: 3 values on X-axis [message #77034 is a reply to message #76877] Mon, 26 September 2005 12:15 Go to previous messageGo to next message
Hi Sam,
BIRT 1.0.1 supports 2D with depth, which gives a 3D look to the chart, but
it's still a 2D chart. BIRT 2.0 will support 3D Charts.
You need to create three series on the Y Axis. You can do that in the the Y
Axis page and then set the Data Definition for each Y Serie.
David
"Sam" <Samuel@xxxx.com> wrote in message
news:5b9427d21ae872690d70a0bb335e362f$1@www.eclipse.org...
> Hello,
> dimensional too ?
> instead of one.
> Sam
Solved-Re: 3 values on X-axis [message #77325 is a reply to message #77034] Tue, 27 September 2005 10:33 Go to previous message
Originally posted by: Sam.xxxxx.com
Hey David,
Thank you for responding.
I got the solution.
Sam
David Michonneau wrote:
> Hi Sam,
> David
>> Hello,
>> dimensional too ?
>> instead of one.
>> Sam
Previous Topic:Text Field in HTML Format
Next Topic:Report Scheduler
Current Time: Sun Aug 31 01:42:58 EDT 2025
Powered by FUDForum. Page generated in 0.03426 seconds
