Home » Archived » XML Schema Definition (XSD) » XSDResourceImpl
XSDResourceImpl [message #75925] Fri, 10 October 2008 00:28 Go to next message
In the class XSDResourceImpl there is a method caled
findSchemas and handleSchemaElement.Can you please explain
the use/functionality of these methods.
Also in the method handleSchemaElement there is a method
parameter called boolean 'isMeta',what does it signify?
Re: XSDResourceImpl [message #75965 is a reply to message #75925] Fri, 10 October 2008 07:18 Go to previous message
Gitanjali,
Comments below.
Gitanjali Punj wrote:
> findSchemas
Typically the schema would be the root element, but in a WSDL document,
there are embedded schemas. This method searches the DOM tree for
<schema> elements from the schema namespace.
That method is called for each <schema> element. An XSDSchema is
created and the <schema> element is associated with that XSDSchema
instance so that the correspond EMF XSD model can be created to
correspond to the structure specified in the DOM.
> Can you please explain the use/functionality of these methods.
> Also in the method handleSchemaElement there is a method parameter
In XSDSchemaImpl the framework needs to manage the special XML Schema
for Schemas, which is the meta schema for all instance schemas. This
schema defines all the built-in simple type definitions and those are
needed by all other non-meta schemas.
Re: XSDResourceImpl [message #603361 is a reply to message #75925] Fri, 10 October 2008 07:18 Go to previous message
Gitanjali,
Comments below.
> findSchemas
Previous Topic:XSDConcreteComponentImpl
Next Topic:XSDConcreteComponentImpl
Current Time: Sat Nov 08 08:35:30 EST 2025
Powered by FUDForum. Page generated in 0.04761 seconds
