Home » Language IDEs » Java Development Tools (JDT) » change $ (user) Name
change $ (user) Name [message #75509] Mon, 14 July 2003 08:28 Go to next message
How can I change the Username for $ (user) in the code that eclipse
generates for me when I add a new class ? Right now it displays my
system-name but I want it alway to display my real name ?
Re: change $ (user) Name [message #75527 is a reply to message #75509] Mon, 14 July 2003 08:43 Go to previous messageGo to next message
Originally posted by: adam_kiezun.ch.ibm.remove.com
there's no way- it takes it from the system properties
if you want it to display your real name simply modify the template
(go to window > preferences > java > code generation > code and comments > comments > types
and change @author ${user} to @author Robert Ludwig )
hth
a.
eclipse.org
Re: change $ (user) Name [message #75555 is a reply to message #75509] Mon, 14 July 2003 09:43 Go to previous message
Originally posted by: olivier_thomann.ca.ibm.comNOSPAM
Le Mon, 14 Jul 2003 12:28:03 +0000 (UTC), SCHWERTFISCHTROMBOSE@GMX.DE
You can change it by passing this argument on the comment line:
-vmargs -Duser.name="You real name" ....
You need to put it at the end of your command line
Olivier
Previous Topic:imports vs. full packages
Next Topic:AST / parser problems
Current Time: Fri Nov 07 21:50:38 EST 2025
Powered by FUDForum. Page generated in 0.06129 seconds
