Home » Language IDEs » AspectJ » An error occurred while automatically activating bundle org.eclipse.ajdt.ui
An error occurred while automatically activating bundle org.eclipse.ajdt.ui [message #71810] Fri, 13 June 2008 15:26 Go to next message
I am new to this ajdt.
I installed apache derby this morning and also ran some junit test on an
already existing projects in my workspace which were running smoothly till
this morning.
Update Manager had downloaded and installed some updates for the
AJDT.After that my workspace seems to be unstable and I cant make the
Derby Network Manager run or any junit tests.
I get the following error message when I run the junit tests.
Plug-in org.eclipse.ajdt.ui was unable to load class
org.eclipse.ajdt.internal.ui.ajde.CachedRuntimeClasspathEntr yResolver.
org.eclipse.ajdt.ui (81).
when I tried running the derby Network Server this is what I got
Error starting Derby Network Server:
Plugin-in org.eclipse.ajdt.ui was unable to load class
Also my eclipse workspace has been giving an error about the workspace
being already in use when ever I start it.
Is there a fix for this or do I revert back to the workspace before the
AJDT update.
If so How can I do it?
Thnx for the help.
Re: An error occurred while automatically activating bundle org.eclipse.ajdt.ui [message #71831 is a reply to message #71810] Mon, 16 June 2008 12:01 Go to previous messageGo to next message
What level of Eclipse and AJDT are you on? Where did you update from?
You will get a faster reply on the mailing list for ajdt than on the
newsgroup.
cheers,
Andy.
Re: An error occurred while automatically activating bundle org.eclipse.ajdt.ui [message #72135 is a reply to message #71810] Thu, 28 August 2008 04:14 Go to previous message
I experienced the same issue. In my case the problem was: the eclipse (->
so the builder) was started with a JRE and not a JDK's JRE (e.g.
jdk1.6_10/jre)
Best regards
Tamas
Re: An error occurred while automatically activating bundle org.eclipse.ajdt.ui [message #597017 is a reply to message #71810] Mon, 16 June 2008 12:01 Go to previous message
newsgroup.
cheers,
Andy.
Re: An error occurred while automatically activating bundle org.eclipse.ajdt.ui [message #599063 is a reply to message #71810] Thu, 28 August 2008 04:14 Go to previous message
jdk1.6_10/jre)
Best regards
Tamas
Previous Topic:How can I find Test Suite in my project
Next Topic:Exception using LTW with signed jars
Current Time: Sat Nov 15 06:06:21 EST 2025
Powered by FUDForum. Page generated in 0.03745 seconds
