Home » Archived » Test and Performance Tools Platform (TPTP) » How to expand a TreeViewer in a view through an IVewPart (verification hook)
How to expand a TreeViewer in a view through an IVewPart (verification hook) [message #70599] Fri, 12 May 2006 06:13 Go to next message
Hello :)
I've done a testCase with the GUI Recorder where I insert a hook on the
package explorer view.
I've downloaded the Ali Mehregani's codes (cf. the
" http://dev.eclipse.org/newslists/news.eclipse.tptp/msg01854. html" news to
know more - very usefull) to get access to the controls located in this
hooked View (the packageExplorer view), and particularly a tree (likely a
TreeViewer).
I've noticed that I can't get control on all the children of the tree in
my code if it isn't fully expanded (am I right or do I need sleep? :p). To
resolve the problem I just add a recursive method to perform a
setExpanded(true) on each tree item.
Surprisingly, it works but just a bit...
The tree is expanded but the expanded items don't show up!
I've somthing like this:
** initial state -, for ex. fully collapsed but it doesn't matter: **
+MyTreeRoot
** I perform the setExpanded)true) through my verification hook and I get
-MyTreeRoot
|_ << nothing
** instead of (for example): **
-MyTreeRoot
|_FirstChild
| |_file1
|_SecondChild
The weird thing is that if I "physically" click on the +MyTreeRoot to
expand it, it perfectly works...
I was wondering if it was due to the cast I made on my tree component (I
did a cast from "Control" to "Tree") because I suppose that the tree in
this view is a TreeViewer.
If someone has a beginning of solution... Cheers
Bertrand.
Re: How to expand a TreeViewer in a view through an IVewPart (verification hook) [message #71425 is a reply to message #70599] Sat, 20 May 2006 19:13 Go to previous messageGo to next message
There could be differences from programmatically expanding a tree vs.
manually expanding it (for example, expansion listeners may not get notified
when programmatically expanding a tree).
I recommend doing an expansion of the tree to the level that you would like
to verify before inserting the hook.
"Bertrand" <bvanier@curamsoftware.com> wrote in message
news:359f743d74ef9fc294a77f6e41969ab6$1@www.eclipse.org...
> Hello :)
> TreeViewer).
> +MyTreeRoot
> -MyTreeRoot
> |_ << nothing
> -MyTreeRoot
> |_FirstChild
> | |_file1
> |_SecondChild
> Bertrand.
Re: How to expand a TreeViewer in a view through an IVewPart (verification hook) [message #71895 is a reply to message #71425] Fri, 26 May 2006 11:06 Go to previous message
Ok thanks for the answer, I'll manually expand the tree so :)
Bertrand.
Previous Topic:Profiling under BEA JRockit JVM
Next Topic:unable to generate .execution file from .testsuite
Current Time: Tue Nov 04 09:43:48 EST 2025
Powered by FUDForum. Page generated in 0.61121 seconds
