Home » Language IDEs » PHP Development Tools (PDT) » Newbie Getting "print" output to browser during debug?
| Newbie Getting "print" output to browser during debug? [message #70588] |
Wed, 14 May 2008 01:20  |
Originally posted by: spam1.makovec.net
Hi all,
Newbie question:
Using XDebug 2.0.3/PHP 5.2.6 here on OS X 10.5.
When debugging as a "PHP Web page" (as opposed to a "PHP Script"), is
there any way to get the script being debugged to generate its output
to the browser immediately? It appears to set some sort of output
buffering occurs.
Take the following piece of code:
<?php
header("content-type: text/html");
print "This is a test<br>\n";
$t = new testme();
$t->doit(2);
print "done<br>\n";
exit(0);
class testme {
public function __construct() {
print "Constructing<br>\n";
error_log("Constructor",0);
* Great little function
* @param int $id - a lovely number
public function doit($id) {
print "Doing it with id $id...<br>\n";
If I set a breakpoint at the "public function doit($id) {" line and hit
Debug, the script appears to execute on the server (the results of the
error_log() are written to the log) up until the breakpoint.
However, none of the "print" calls appear to be getting executed until
I restart the process, click "Remote Launch" in the Debug view and then
the "Terminate" button - at which point all the output is displayed and
the process exits (at which point a second browser window opens for me
saying "DEBUG SESSION ENDED".
Is there any way I could configure PDT/XDebug to instruct PHP to output
the results of the print calls immediately, rather than waiting for the
debugging session to end?
Thanks in advance!
| Re: Newbie Getting "print" output to browser during debug? [message #70796 is a reply to message #70588] |
Wed, 14 May 2008 04:37   |
Hi Dan, xdebug 2.0.3 is not supported unfortunately. The author made a change in 2.0.3 which altered
the protocol and as such PDT 1.0.2 cannot work correctly with it. As you have experienced, the
debug session never terminates when the request ends. For PDT 1.0.2 you need to use Xdebug 2.0.2.
Support for Xdebug 2.0.3 wil be available in PDT 1.0.3 and PDT 1.1.
It looks like you can get xdebug 2.0.2 from the following link
http://www.xdebug.org/link.php?url=xdebug202-52-win
As for your other issue, you may want to take a look at flush() for more information.
http://www.php.net/flush
Dave Kelsey.
Dan wrote:
> Hi all,
> Newbie question:
> there any way to get the script being debugged to generate its output to
> buffering occurs.
> <?php
> $t = new testme();
> $t->doit(2);
> print "done<br>\n";
> exit(0);
> class testme {
> However, none of the "print" calls appear to be getting executed until I
> Thanks in advance!
| Re: Newbie Getting "print" output to browser during debug? [message #70802 is a reply to message #70796] |
Wed, 14 May 2008 08:44   |
Hi Dave,
Fantastic, thanks for the super quick response! I'll downgrade to
2.0.2 right away. I actually was running 2.0.2 and only upped to 2.0.3
when I saw it today on the site. So much for dot-dot releases
maintaining backward compatibility!
> change in 2.0.3 which altered the protocol and as such PDT 1.0.2
> cannot work correctly with it. As you have experienced, the debug
> to use Xdebug 2.0.2. Support for Xdebug 2.0.3 wil be available in PDT
> 1.0.3 and PDT 1.1.
> more information.
> Dave Kelsey.
> Dan wrote:
>> Hi all,
>> Newbie question:
>> buffering occurs.
>> <?php
>> $t = new testme();
>> $t->doit(2);
>> print "done<br>\n";
>> exit(0);
>> class testme {
>> Thanks in advance!
| Re: Newbie Getting "print" output to browser during debug? [message #70811 is a reply to message #70802] |
Wed, 14 May 2008 11:04   |
It would not be possible to maintain backward compatibility with the change that was made. It was an
area of the specification that wasn't clear if it had to be explicitly handled or not and as xdebug
prior to 2.0.3 didn't use it, I hadn't implemented code to handle it, so cant really blame Derick
for the problem.
PDT 1.0.3 should be able to handle xdebug 2.0.2 and 2.0.3 without any problems. I don't think the
support made it into 1.0.3rc1 through.
Dave Kelsey
Dan wrote:
> Hi Dave,
> Fantastic, thanks for the super quick response! I'll downgrade to 2.0.2
> right away. I actually was running 2.0.2 and only upped to 2.0.3 when I
> saw it today on the site. So much for dot-dot releases maintaining
>> 1.0.3 and PDT 1.1.
>> more information.
>> Dave Kelsey.
>> Dan wrote:
>>> Hi all,
>>> Newbie question:
>>> buffering occurs.
>>> <?php
>>> $t = new testme();
>>> $t->doit(2);
>>> print "done<br>\n";
>>> exit(0);
>>> class testme {
>>> hit Debug, the script appears to execute on the server (the results
>>> of the error_log() are written to the log) up until the breakpoint.
>>> until I restart the process, click "Remote Launch" in the Debug view
>>> and then the "Terminate" button - at which point all the output is
>>> displayed and the process exits (at which point a second browser
>>> window opens for me saying "DEBUG SESSION ENDED".
>>> output the results of the print calls immediately, rather than
>>> waiting for the debugging session to end?
>>> Thanks in advance!
| Re: Newbie Getting "print" output to browser during debug? [message #70856 is a reply to message #70811] |
Wed, 14 May 2008 20:24   |
Hi Dave,
I downgraded to XDebug 2.0.2 this morning. Running PDT
1.0.3.v20080429-79-7PE7QYGHNGqZW, as downloaded from Eclipse.org
yesterday. Killed and restarted Apache and Eclipse to ensure all
traces of xdebug 2.0.3 were gone.
I tried using the following script:
<?php
print "A<br>\n";
print "B<br>\n";
print "C<br>\n";
print "D<br>\n";
I set a breakpoint at the print "C<br>\n"; line. Selecting "debug as
web page", I would expect to see the output:
A
B
then have the script suspend at line 4.
However, the browser window pops up empty (I've tried with both Firefox
and Safari), and the script is suspended at line 4. As soon as I click
"Resume", I get the full output:
A
B
C
D
Very weird! But it gets weirder.
I change the above script to:
<?php
phpinfo();
print "A<br>\n";
print "B<br>\n";
print "C<br>\n";
print "D<br>\n";
and keep the breakpoint in the same place.
This time when I click "Debug", the phpinfo() output is displayed
immediately - up until about half way through the "Environment" table,
but neither of the two print calls display. Once again, the script is
suspended at my breakpoint, and clicking "Resume" completes the
phpinfo() output and outputs all my prints.
It sounds like there's some sort of output buffering going on, but I've
set output_buffering=0 in my php.ini
Any ideas?
> change that was made. It was an area of the specification that wasn't
> clear if it had to be explicitly handled or not and as xdebug prior to
> really blame Derick for the problem.
> problems. I don't think the support made it into 1.0.3rc1 through.
> Dave Kelsey
> Dan wrote:
>> Hi Dave,
>>> 1.0.3 and PDT 1.1.
>>> more information.
>>> Dave Kelsey.
>>> Dan wrote:
>>>> Hi all,
>>>> Newbie question:
>>>> buffering occurs.
>>>> <?php
>>>> $t = new testme();
>>>> $t->doit(2);
>>>> print "done<br>\n";
>>>> exit(0);
>>>> class testme {
>>>> Thanks in advance!
| Re: Newbie Getting "print" output to browser during debug? [message #70893 is a reply to message #70856] |
Wed, 14 May 2008 20:32  |
Aha! Found the culprit.
When I installed PHP, I used the supplied php.ini-recommended as the
basis for my configuration. This includes the non-default directive:
implicit_flush = Off
Changing this to On fixed the problem!
Thanks for your help Dave!
On 2008-05-15 10:24:25 +1000, Dan <spam1@makovec.net> said:
> Hi Dave,
> <?php
> print "A<br>\n";
> print "B<br>\n";
> print "C<br>\n";
> print "D<br>\n";
> A
> B
> A
> B
> C
> D
> <?php
> phpinfo();
> print "A<br>\n";
> print "B<br>\n";
> print "C<br>\n";
> print "D<br>\n";
> Any ideas?
>> Dave Kelsey
>> Dan wrote:
>>> Hi Dave,
>>>> 1.0.3 and PDT 1.1.
>>>> more information.
>>>> Dave Kelsey.
>>>> Dan wrote:
>>>>> Hi all,
>>>>> Newbie question:
>>>>> buffering occurs.
>>>>> <?php
>>>>> $t = new testme();
>>>>> $t->doit(2);
>>>>> print "done<br>\n";
>>>>> exit(0);
>>>>> class testme {
>>>>> Thanks in advance!
Current Time: Wed Nov 05 01:00:47 EST 2025
Powered by FUDForum. Page generated in 0.04998 seconds
