Home » Eclipse Projects » GEF » Overview panel and negative coordinates PROBLEM
Overview panel and negative coordinates PROBLEM [message #70229] Thu, 13 March 2003 20:57 Go to next message
I just noticed that overview panel seems to not handle negative
coordinates properly. For example in Logic example just try draging any of
the components off to the left or top of the screen so that canvas is
expanded into negative coordinate territory. After that the overview panel
itself is off to the left and you can no longer see the whole root figure
in it. Is this a bug?
Thanks a lot,
-Vadim
Re: Overview panel and negative coordinates PROBLEM [message #71018 is a reply to message #70229] Mon, 17 March 2003 10:17 Go to previous messageGo to next message
I opened a bug (http://bugs.eclipse.org/bugs/show_bug.cgi?id=35143).
Add yourself to the CC list if you're interested.
Eric
Vadim Strizhevsky wrote:
> Hello,
> Thanks a lot,
> -Vadim
Re: Overview panel and negative coordinates PROBLEM [message #71157 is a reply to message #71018] Mon, 17 March 2003 21:13 Go to previous messageGo to next message
Originally posted by: Vadim.Strizhevsky.morganstanley_dot_.com
Thanks! Do you prefer that things of the same nature be opened as bugs
directly in future, or posts to this newsgroup?
-Vadim
> Eric
> > Hello,
> > Thanks a lot,
> > -Vadim
Re: Overview panel and negative coordinates PROBLEM [message #71177 is a reply to message #71157] Mon, 17 March 2003 22:18 Go to previous message
If you can demonstrate the problem directly in the example, and you are
using code within the last 2 weeks, open a bugzilla. If you think others
might open duplicates, you could post the bugzilla URL to the newsgroup.
We appreciate the help!
"Vadim Strizhevsky" <Vadim.Strizhevsky@morganstanley_dot_.com> wrote in
message news:b55vcp$ot7$1@rogue.oti.com...
> -Vadim
> > Eric
> > > Hello,
any of
panel
figure
> > > Thanks a lot,
> > > -Vadim
Previous Topic:Drag and Drop with Control Key pressed
Next Topic:how to hide some visual figure
Current Time: Sat Oct 25 05:44:07 EDT 2025
Powered by FUDForum. Page generated in 0.04479 seconds
