| Nebula widgets in RAP [message #69699] |
Thu, 10 January 2008 04:43  |
Originally posted by: benedikt.arnold.beyondsoft.de
I filed a feature request against the nebula project. I asked if they could
use Import-Package instead of Require-Bundle.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=214867
With Import-Package it would be easy to use nebula widgets in RAP in the
future. Ok there are some limitations because RWT has not a 100% compatible
SWT-Api, but thats not a nebula problem. The limitations that I encountered
are missing key listeners, but implementing this is targeted for RAP 1.1M2
if the Plan is correct.
Greetings,
Ben
Benedikt Arnold
wadenkrampf.blogspot.com
| Re: Nebula widgets in RAP [message #70692 is a reply to message #70645] |
Fri, 18 January 2008 03:56  |
Hi Frank,
Positive. Allthough it is working there's still some work to do.
I will ask big chief of our tribe ;-)
Oliver
Frank Appel schrieb:
> Hi Oliver,
> do I understand you answer correctly that you have a RAP DateChooser widget
> based on the qooxdoo DateChooser? Is there any chance to open this
> implementation to others?just asking :-)
> Ciao
> Frank
> "Poncho" <sasfatu@gmx.de> schrieb im Newsbeitrag
> news:fmn023$59p$1@build.eclipse.org...
>> Hi Benedikt,
>> at least the DateChooser widget should be no problem.
>> As there is a working DateChooser widget in qooxdoo
>> (i.e. the underlying javascript framework for RAP) it is possible
>> to implement such a widget in RAP.
>> We've already done this in our project.
>> You can check the forum and the RAP Project site for any help on how
>> to implement your own custom widgets.
>> Regards
>> Oliver
>> Benedikt Arnold schrieb:
>>> Hi,
>>> could use Import-Package instead of Require-Bundle.
>>> compatible SWT-Api, but thats not a nebula problem. The limitations that
>>> I encountered are missing key listeners, but implementing this is
>>> targeted for RAP 1.1M2 if the Plan is correct.
>>> Greetings,
>>> Ben
FUDForum. Page generated in 0.03238 seconds
