Home » Eclipse Projects » Equinox » re: Deploying servlet on a tomcat
re: Deploying servlet on a tomcat [message #69673] Wed, 12 July 2006 01:39 Go to next message
Originally posted by: skaegi.sympatico.ca
Hi Khawaja,
It sounds like you have everything deployed correctly. If you deployed the
webapp overtop of an existing install it's a good idea to "sp_clean" your
environment.
In terms of next steps... by default the "console" is launched which you can
use to verify that everything is installed and started correctly. I'd spend
some time learning the console commands as they're invaluable when tracking
down problems.
All requests are proxied through the BridgeServlet. You can access the
servlet and resource registered by the "sample.http" bundle at "/helloworld"
and "/helloworld.html" relative to the context where you installed the war.
e.g. http://localhost:8080/bridge/helloworld
If you're using "sample.http.registry" try "/ext/helloworld" and
"/ext/helloworld.html" again prefixed by your ServletContext path.
Hope this helps.
-Simon
[mailto:equinox-dev-bounces@eclipse.org] On Behalf Of Khawaja Shams
Sent: Tuesday, July 11, 2006 8:33 PM
To: Equinox development mailing list
Subject: [equinox-dev] Deploying servlet on a tomcat
I was able to deploy my servlet on the osgi framework within Eclipse,
and all the needed services worked fine. My next step is to deploy this
project on our production tomcat instance. I am looking at the following
guide:
http://www.eclipse.org/equinox/incubator/server/embedding_in _a_servlet_container.php
I have deployed bridge.war, and the sp_test context shows that the bridge
is deployed successfully. I have also downloaded the sample applications.
I followed the instructions on the build process section, and I have the
following directory structure:
RangeMapServle/t
WEB-INF/
web.xml (same as sample web application)
lib/
servlet-bridge.jar
platform/
plugins/
all my dependent plugins along with everything in
this folder of the sample web application (without registry)
features/
feature.xml (same as the sample application + my
bundle added to the description)
configuration/
config.ini (same as sample + an @start for my
bundle
launch.ini
I am curious what the next step should be. I tried creating a war archive
and placing it in tomcat's webapp directory. Tomcat's log shows an attempt
to deploy the application as well. However, I am not sure if properly
deployed or not. Moreover, how would I access the servlet? Would it be
accessed through the bridge servlet? If there are any instructions on how to
access the sample application once deployed, I would like to see them. I
ran the WebAppBuilder.xml script in the launcher, and I saw the directory
structure. However, I am still unsure of how to deploy the application. I
would sincerely appreciate any help.
Khawaja
Re: Deploying servlet on a tomcat [message #69713 is a reply to message #69673] Wed, 12 July 2006 15:14 Go to previous messageGo to next message
Originally posted by: ksshams.gmail.com
Thank you Simon for your help so far.
1) Where is the console launched? When I start tomcat, I see the osgi
prompt as part of the logs, but I am not sure how to execute commands on
it.
2) I am not sure I see an sp_clean option in the bridge servlet. I
tried it, and it did not work. Does sp_redeploy result in similar
functionality?
Currently, when I deploy the servlet, I cannot access the helloworld
application. I am hitting the url:
I am attaching my bridge folder as a zipped archived. Can anyone give
me some pointers on where I am going wrong? I am placing the
unarchived folder in the webapps folder of tomcat5.5.17. Thank you for
your time and help.
Khawaja
Simon Kaegi wrote:
> Hi Khawaja,
> environment.
> down problems.
> Hope this helps.
> -Simon
> From: equinox-dev-bounces@eclipse.org
> Hello,
> guide:
> RangeMapServle/t
> WEB-INF/
> lib/
> servlet-bridge.jar
> platform/
> plugins/
> features/
> configuration/
> bundle
> launch.ini
> Khawaja
Re: Deploying servlet on a tomcat [message #69734 is a reply to message #69713] Wed, 12 July 2006 15:18 Go to previous messageGo to next message
--------------010208060401020007060707
My attachment was too big, so it did not go through. Here are the
vital files. Also, here is a listing of what is in the plugin directory:
org.eclipse.equinox.common_3.2.0.v20060603.jar
org.eclipse.equinox.http.registry_3.2.0.200607121155.jar
org.eclipse.equinox.registry_3.2.0.v20060601.jar
org.eclipse.equinox.servlet.api_1.0.0.v20060601.jar
org.eclipse.equinox.servlet.bridge.extensionbundle_3.2.0
org.eclipse.equinox.servlet.bridge.http_3.2.0.200607121155.j ar
org.eclipse.osgi.services_3.1.100.v20060601.jar
org.eclipse.osgi_3.2.0.v20060601.jar
org.eclipse.update.configurator_3.2.0.v20060511.jar
sample.http_1.0.0.jar
Thanks again.
Khawaja
Khawaja Shams wrote:
> Hello,
> it.
> functionality?
> your time and help.
> Khawaja
> Simon Kaegi wrote:
>> Hi Khawaja,
>> the
>> environment.
>> you can
>> spend
>> tracking
>> down problems.
>> "/helloworld"
>> war.
>> Hope this helps.
>> -Simon
>> Hello,
>> Eclipse,
>> guide:
>> bridge
>> applications.
>> RangeMapServle/t
>> WEB-INF/
>> lib/
>> servlet-bridge.jar
>> platform/
>> plugins/
>> everything in
>> features/
>> configuration/
>> bundle
>> launch.ini
>> archive
>> attempt
>> how to
>> application. I
>> Regards,
>> Khawaja
Content-Type: text/xml;
name="feature.xml"
Content-Disposition: inline;
filename="feature.xml"
<feature
id="org.eclipse.equinox.servlet.bridge.feature"
label="org.eclipse.equinox.servlet.bridge.feature"
version="1.0.0">
<description>
Servlet Bridge Feature
</description>
<copyright>
2006 Eclipse Foundation and others.
</copyright>
<license url="http://www.eclipse.org/legal/epl-v10.html">
ECLIPSE FOUNDATION SOFTWARE USER AGREEMENT
</license>
<requires>
<import plugin="org.eclipse.equinox.common" version="3.2.0" match="compatible"/>
<import plugin="org.eclipse.core.jobs"/>
<import plugin="org.eclipse.osgi" version="3.2.0" match="compatible"/>
<import plugin="org.eclipse.equinox.servlet.bridge.launcher"/>
</requires>
<plugin
id="org.eclipse.osgi"
download-size="0"
install-size="0"
version="3.2.0.v20060601"
unpack="false"/>
<plugin
id="org.eclipse.osgi.services"
download-size="0"
install-size="0"
version="3.1.100.v20060601"
unpack="false"/>
<plugin
id="org.eclipse.equinox.common"
download-size="0"
install-size="0"
version="3.2.0.v20060603"
unpack="false"/>
<plugin
id="org.eclipse.equinox.registry"
download-size="0"
install-size="0"
unpack="false"/>
<plugin
id="org.eclipse.update.configurator"
download-size="0"
install-size="0"
version="3.2.0.v20060511"
unpack="false"/>
<plugin
id="org.eclipse.equinox.http.registry"
download-size="0"
install-size="0"
version="3.2.0.200607121155"
unpack="false"/>
<plugin
id="org.eclipse.equinox.servlet.bridge.http"
download-size="0"
install-size="0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.servlet.api"
download-size="0"
install-size="0"
version="1.0.0.v20060601"
unpack="false"/>
<plugin
id="sample.http"
download-size="0"
install-size="0"
version="1.0.0"
unpack="false"/>
</feature>
name="config.ini"
filename="config.ini"
#Eclipse Runtime Configuration File
osgi.bundles=org.eclipse.equinox.common@2:start, org.eclipse.update.configurator@start, org.eclipse.equinox.servlet.bridge.http@start, org.eclipse.equinox.http.registry@start
osgi.bundles.defaultStartLevel=4
name="web.xml"
filename="web.xml"
<!DOCTYPE web-app PUBLIC "-//Sun Microsystems, Inc.//DTD Web Application 2.2//EN" "http://java.sun.com/j2ee/dtds/web-app_2_2.dtd">
<web-app id="WebApp">
<servlet id="bridge">
<servlet-name>equinoxbridgeservlet</servlet-name>
<display-name>Equinox Bridge Servlet</display-name>
<description>Equinox Bridge Servlet</description>
<servlet-class>org.eclipse.equinox.servlet.bridge.launcher.BridgeServlet </servlet-class>
<init-param>
<param-name>commandline</param-name>
<param-value>-console</param-value>
</init-param>
<init-param>
<param-name>enableFrameworkControls</param-name>
<param-value>true</param-value>
</init-param>
You can specify your own framework launcher here.
The default is: org.eclipse.equinox.servlet.bridge.launcher.FrameworkLaunche r
<init-param>
<param-name>frameworkLauncherClass</param-name>
<param-value> org.eclipse.equinox.servlet.bridge.launcher.FrameworkLaunche r </param-value>
</init-param>
<load-on-startup>1</load-on-startup>
</servlet>
<servlet-mapping>
<url-pattern>/*</url-pattern>
</servlet-mapping>
</web-app>
--------------010208060401020007060707--
Re: Deploying servlet on a tomcat [message #69753 is a reply to message #69734] Wed, 12 July 2006 23:08 Go to previous messageGo to next message
Hi Khawaja,
It looks like everything is there but my guess is that the problem is that
the sample.http bundle is not started.
You can add sample.http@start in your config.ini to have the bundle
automatically started or else use the console to manually start it.
I've included a config.ini and feature.xml that I put together for this
purpose. (less fancy than your feature.xml but notice that the servlet.api
bundle is not packaged in the war file as the servlet container will supply
it)
Here is the result of an "ss" from the console.
osgi> ss
Framework is launched.
id State Bundle
0 ACTIVE system.bundle_3.2.0.v20060601
Fragments=8
1 ACTIVE org.eclipse.equinox.common_3.2.0.v20060603
2 ACTIVE org.eclipse.update.configurator_3.2.0.v20060605
3 ACTIVE
org.eclipse.equinox.servlet.bridge.http_3.2.0.200607122227
4 ACTIVE org.eclipse.equinox.http.registry_3.2.0.200607122227
7 ACTIVE org.eclipse.equinox.registry_3.2.0.v20060601
8 RESOLVED org.eclipse.equinox.servlet.bridge.extensionbundle_3.2.0
Master=0
10 RESOLVED org.eclipse.osgi.services_3.1.100.v20060601
13 ACTIVE sample.http_1.0.0
Speaking of which...
> it.
By default the console is launched using stdin/stdout. If you launch tomcat
from the command e.g. "bin/startup.bat" you can use the console directly.
Keep in mind that the console is more a dev tool useful to get a feel for
things. Type "help" for console commands. "ss" is particularly useful ;)
Once you've got the basics nailed down you might want to take a look at the
http-console packaged at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=122911
> functionality?
Yes, you're right sp_clean was an old command that eventually became
sp_undeploy. sp_redeploy will give you the desired result.
GL
-Simon
"Khawaja Shams" <ksshams@gmail.com> wrote in message
news:e93hu9$fnj$1@utils.eclipse.org...
> Hello,
> Thanks again.
> Khawaja
> > Hello,
> > it.
> > functionality?
> > your time and help.
> > Regards,
> > Khawaja
> > Simon Kaegi wrote:
> >> Hi Khawaja,
> >> the
your
> >> environment.
> >> you can
> >> spend
> >> tracking
> >> down problems.
> >> "/helloworld"
> >> war.
> >> Hope this helps.
> >> -Simon
> >> Hello,
> >> Eclipse,
this
following
> >> guide:
> >> bridge
> >> applications.
the
> >> RangeMapServle/t
> >> WEB-INF/
> >> lib/
> >> servlet-bridge.jar
> >> platform/
> >> plugins/
> >> everything in
> >> features/
my
> >> configuration/
> >> bundle
> >> launch.ini
> >> archive
> >> attempt
> >> how to
I
directory
> >> application. I
> >> Regards,
> >> Khawaja
> <feature
> version="1.0.0">
> <description>
> </description>
> <copyright>
> </copyright>
> </license>
> <requires>
> </requires>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> id="sample.http"
> download-size="0"
> install-size="0"
> version="1.0.0"
> unpack="false"/>
> </feature>
rvlet-class>
> <init-param>
> </init-param>
> <init-param>
> </init-param>
> The default is:
> <init-param>
param-value>
> </init-param>
> </servlet>
> <servlet-mapping>
> </servlet-mapping>
> </web-app>
  • Attachment: config.ini
    (Size: 0.26KB, Downloaded 199 times)
  • Attachment: feature.xml
    (Size: 1.82KB, Downloaded 448 times)
Re: Deploying servlet on a tomcat [message #70956 is a reply to message #69753] Wed, 26 July 2006 14:49 Go to previous messageGo to next message
Hello again,
Thank you for all your help so far. Our servlet is up and running
on tomcat without any problems (on a windows machine). I have a few
more questions.
1) When I start tomcat on windows, a new window pops up with the logs
and has an osgi prompt. However, this is not the case for a linux (when
I start tomcat using startup.sh). All the logs are being directed to
catalina.out, and I can see the osgi prompt inside the file.
2) Are there any instructions on using the http-console bundle? I tried
using it by putting in my platform/plugins folder and added an @start
for this bundle in my config.ini file. However, I cannot see anything
when I go to http://localhost:8080/bridge/console. Is there anything
that I am missing?
Thanks in advance.
Khawaja Shams
Simon Kaegi wrote:
> Hi Khawaja,
> it)
> osgi> ss
> id State Bundle
> Fragments=8
> 3 ACTIVE
> Master=0
>>it.
>>functionality?
> GL
> -Simon
>>Hello,
>>Thanks again.
>>Khawaja
>>>Hello,
>>>it.
>>>functionality?
>>>your time and help.
>>>Regards,
>>>Khawaja
>>>Simon Kaegi wrote:
>>>>Hi Khawaja,
>>>>the
> your
>>>>environment.
>>>>you can
>>>>spend
>>>>tracking
>>>>down problems.
>>>>"/helloworld"
>>>>war.
>>>>Hope this helps.
>>>>-Simon
>>>> Hello,
>>>>Eclipse,
> this
> following
>>>>guide:
>>>>bridge
>>>>applications.
> the
>>>> RangeMapServle/t
>>>> WEB-INF/
>>>> lib/
>>>> servlet-bridge.jar
>>>> platform/
>>>> plugins/
>>>>everything in
>>>> features/
> my
>>>> configuration/
>>>>bundle
>>>> launch.ini
>>>>archive
>>>>attempt
>>>>how to
> I
> directory
>>>>application. I
>>>> Regards,
>>>> Khawaja
>><?xml version="1.0" encoding="UTF-8"?>
>><feature
>> version="1.0.0">
>> <description>
>> </description>
>> <copyright>
>> </copyright>
>> </license>
>> <requires>
>> </requires>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> id="sample.http"
>> download-size="0"
>> install-size="0"
>> version="1.0.0"
>> unpack="false"/>
>></feature>
> rvlet-class>
>><init-param>
>></init-param>
>><init-param>
>></init-param>
>> The default is:
>><init-param>
> param-value>
>></init-param>
>></servlet>
>><servlet-mapping>
>></servlet-mapping>
>></web-app>
> <feature
> version="1.0.0">
> <description>
> </description>
> <copyright>
> </copyright>
> </license>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> version="3.2.0.v20060605"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> version="3.2.0.200607122227"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> id="sample.http"
> download-size="0"
> install-size="0"
> version="1.0.0"
> unpack="false"/>
> </feature>
Re: Deploying servlet on a tomcat [message #71051 is a reply to message #70956] Wed, 26 July 2006 15:48 Go to previous message
Try http://localhost:8080/bridge/servlet/console ;)
For the problems with basic I/O on linux using Tomcat... removing the line
in catalina.sh that pipes to "catalina.out" should do it
(... or Jetty on Linux doesn't do this)
-Simon
news:ea8dg9$9vd$1@utils.eclipse.org...
> Hello again,
> more questions.
> that I am missing?
> Thanks in advance.
> Khawaja Shams
> Simon Kaegi wrote:
> > Hi Khawaja,
that
servlet.api
supply
> > it)
> > osgi> ss
> > id State Bundle
> > Fragments=8
> > 3 ACTIVE
> > 8 RESOLVED
> > Master=0
> >>it.
tomcat
directly.
for
the
> >>functionality?
> > GL
> > -Simon
> >>Hello,
directory:
> >>Thanks again.
> >>Khawaja
> >>>Hello,
on
> >>>it.
> >>>functionality?
> >>>your time and help.
> >>>Regards,
> >>>Khawaja
> >>>Simon Kaegi wrote:
> >>>>Hi Khawaja,
> >>>>the
> > your
> >>>>environment.
> >>>>you can
> >>>>spend
> >>>>tracking
> >>>>down problems.
> >>>>"/helloworld"
> >>>>war.
> >>>>Hope this helps.
> >>>>-Simon
> >>>> Hello,
> >>>>Eclipse,
> > this
> > following
> >>>>guide:
> >>>>bridge
> >>>>applications.
> > the
> >>>> RangeMapServle/t
> >>>> WEB-INF/
> >>>> lib/
> >>>> servlet-bridge.jar
> >>>> platform/
> >>>> plugins/
> >>>>everything in
> >>>> features/
> > my
> >>>> configuration/
> >>>>bundle
> >>>> launch.ini
> >>>>archive
> >>>>attempt
be
> >>>>how to
> > I
> > directory
> >>>>application. I
> >>>> Regards,
> >>>> Khawaja
> >><feature
> >> version="1.0.0">
> >> <description>
> >> </description>
> >> <copyright>
> >> </copyright>
> >> </license>
> >> <requires>
> >> </requires>
> >> <plugin
> >> download-size="0"
> >> install-size="0"
> >> unpack="false"/>
> >> <plugin
> >> download-size="0"
> >> install-size="0"
> >> unpack="false"/>
> >> <plugin
> >> download-size="0"
> >> install-size="0"
> >> unpack="false"/>
> >> <plugin
> >> download-size="0"
> >> install-size="0"
> >> unpack="false"/>
> >> <plugin
> >> download-size="0"
> >> install-size="0"
> >> unpack="false"/>
> >> <plugin
> >> download-size="0"
> >> install-size="0"
> >> unpack="false"/>
> >> <plugin
> >> download-size="0"
> >> install-size="0"
> >> unpack="false"/>
> >> <plugin
> >> download-size="0"
> >> install-size="0"
> >> unpack="false"/>
> >> <plugin
> >> id="sample.http"
> >> download-size="0"
> >> install-size="0"
> >> version="1.0.0"
> >> unpack="false"/>
> >></feature>
> > rvlet-class>
> >><init-param>
> >></init-param>
> >><init-param>
> >></init-param>
> >> The default is:
> >><init-param>
> > param-value>
> >></init-param>
> >></servlet>
> >><servlet-mapping>
> >></servlet-mapping>
> >></web-app>
> > <feature
> > version="1.0.0">
> > <description>
> > </description>
> > <copyright>
> > </copyright>
> > </license>
> > <plugin
> > download-size="0"
> > install-size="0"
> > unpack="false"/>
> > <plugin
> > download-size="0"
> > install-size="0"
> > unpack="false"/>
> > <plugin
> > download-size="0"
> > install-size="0"
> > unpack="false"/>
> > <plugin
> > download-size="0"
> > install-size="0"
> > unpack="false"/>
> > <plugin
> > download-size="0"
> > install-size="0"
> > unpack="false"/>
> > <plugin
> > download-size="0"
> > install-size="0"
> > unpack="false"/>
> > <plugin
> > download-size="0"
> > install-size="0"
> > unpack="false"/>
> > <plugin
> > id="sample.http"
> > download-size="0"
> > install-size="0"
> > version="1.0.0"
> > unpack="false"/>
> > </feature>
Previous Topic:Initial Provisioning: prevent others from installing bundles
Next Topic:Help Me A Hello World Service ?
Current Time: Wed Oct 22 11:08:03 EDT 2025
Powered by FUDForum. Page generated in 0.56416 seconds
