Home » Archived » BIRT » cannot see the onRender method after on Birt v1.0.1
cannot see the onRender method after on Birt v1.0.1 [message #69543] Thu, 25 August 2005 06:57 Go to next message
Originally posted by: gsunil.digite.com
I have installed Birt v1.0 on Eclipse3.0 and was able to see both onCreate
and onRender methods in the code dropdown for report items. I have now
upgraded to Eclipse v3.1 and Birt v1.0.1, but now, only onCreate method is
visible in the dropdown of report items. Any idea why the onRender method
has disappeared?
Thanks!
Sunil
Re: cannot see the onRender method after on Birt v1.0.1 [message #69563 is a reply to message #69543] Thu, 25 August 2005 08:41 Go to previous message
I believe onRender was removed because it was not being called by the
engine. See bug#102496 https://bugs.eclipse.org/bugs/show_bug.cgi?id=102496
It appears that BIRT is planning on supporting the onRender method in
the 2.0 release.
Sunil wrote:
> onCreate and onRender methods in the code dropdown for report items. I
> have now upgraded to Eclipse v3.1 and Birt v1.0.1, but now, only
> onCreate method is visible in the dropdown of report items. Any idea why
> the onRender method has disappeared?
> Thanks!
> Sunil
Previous Topic:Page Numbering in PDF Report
Next Topic:problem with API
Current Time: Sat Nov 08 21:22:05 EST 2025
Powered by FUDForum. Page generated in 0.25524 seconds
