Home » Modeling » OCL » Navigate through a model
Navigate through a model [message #67457] Mon, 09 February 2009 20:00 Go to next message
in the UML2Tools Classdiagram this ocl constraint is evaluated:
let result : Set(Type) = Set{} in
let pakkage : Package = self.getNearestPackage()
let siblings : Set(Type) = pakkage.ownedType in
let imports : Bag(Type) =
pakkage.elementImport->select(importedElement.oclIsKindOf(Type)
and (importedElement.oclIsKindOf(Class) implies not
importedElement.oclAsType(Class).isMetaclass())
)->collect(importedElement.oclAsType(Type)) in
result->union(siblings)->union(imports->asSet())
This gets the Elements in the actual Package.
The structure of my Model is always:
Model test
Package Classes
Package A
Package B
Package C
The constraint is evaluated in Package C but I want Elements from the
Package "Classes". Is this possible?
Thank you
Peter
Re: Navigate through a model [message #67518 is a reply to message #67457] Tue, 10 February 2009 09:53 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Peter,
Why is this constraint only evaluated in the C package? What is the
context of this constraint? Is it Package or Classifier? It should be
evaluated on *every* instance of the context metaclass.
In any case, you have at least a few options to navigate from package C
to Classes:
- directly:
self.getModel().getNestedPackage('Classes')
- indirectly:
Package.allInstances->any(qualifiedName = 'test::Classes')
Or, you could define the constraint in the Package context and introduce
a condition on the package name:
context Package
inv:
if qualifiedName <> 'test::Classes' then Set{} else
let result : Set(Type) = Set{},
siblings : Set(Type) = self.ownedType,
in
endif
Although, this isn't a boolean valued expression, so I'm assuming it is
some kind of operation body expression?
Incidentally, it could be expressed more straightforwardly to take
imports into account, thus:
self.member->iterate(e; result : Set(Type) = Set{} |
if e.oclIsKindOf(Type) and not (e.oclIsKindOf(Class) and
e.oclAsType(Class).isMetaclass()) then
result->including(e.oclAsType(Type))
else
result
endif)
HTH,
Christian
Peter wrote:
> implies not importedElement.oclAsType(Class).isMetaclass())
> Model test
> Package Classes
> Package A
> Package B
> Package C
> Thank you
> Peter
Re: Navigate through a model [message #67561 is a reply to message #67518] Tue, 10 February 2009 12:10 Go to previous messageGo to next message
Hi Christian,
first Thank you for your answer!
Sorry I should explained that.
This constraint get the Classifier Elements for a InstanceSpecification.
When I set a name of a Instance Specification it`s also possible to set
the Classifier with ": Classifier". The constraint gets the possible
Classifiers.
So its evaluated on a InstanceSpecification.
> to Classes:
> - directly:
I already tried that. The OCL Console says
Results:
Cannot find operation (getNestedPackage(String)) for the type (Model)
> - indirectly:
> Package.allInstances()->any(qualifiedName = 'test::Classes')
This works. But not when the actual Element is an InstanceSpecification?
When I evaluate this on a Instance Specification:
self.getModel().name.concat('::Classes')).member->iterate(e; result :
Set(Type) = Set{} |
else
result
endif)
Results:
OclInvalid
When I evaluate it on a Class or a Package it gets the Classifier Elements.
Any suggestion?
> self.getNearestPackage().member->iterate(e; result : Set(Type) = Set{} |
> else
> result
> endif)
This works perfect on the actual Package with the little Change:
The UML2Tools Guys should use it if this is better.
Peter
> Peter wrote:
>> let pakkage : Package = self.getNearestPackage() in
>> implies not
>> Model test
>> Package Classes
>> Package A
>> Package B
>> Package C
>> Thank you
>> Peter
Re: Navigate through a model [message #67591 is a reply to message #67561] Tue, 10 February 2009 16:24 Go to previous messageGo to next message
Hi, Peter,
See some comments in-line, below.
HTH,
Christian
Peter wrote:
> Hi Christian,
>> be evaluated on *every* instance of the context metaclass.
Ah! That'll be the root of your problem. More on that, below.
> Classifiers.
>> C to Classes:
>> - directly:
> Results:
Doh! Sorry, silly me. This is only a Java method produced by the UML2
code generator. Is has no correspondent in OCL. But, you could emulate
it with:
self.getModel().nestedPackage->any(name = 'Classes')
>> - indirectly:
The problem with instance specifications is that the OCL interpreter
supports evaluating OCL constraints and expressions on them that are
defined in the context of the instance's classifiers, to simulate their
evaluation in the run-time system. That is, since
InstanceSpecifications are (partial) models (at M1 level) of run-time
objects (the M0 level), we can evaluate the OCL constraints of their
classifiers on them. However, as they are nonetheless model elements,
one also wants to be able to treat InstanceSpecifications as M1
instances of the M2 InstanceSpecification metaclass, and evaluate
constraints defined at that level.
The default configuration of the OCL interpreter is to treat
InstanceSpecifications as like M0 objects (evaluating on them
expressions defined in the context of their classifiers) rather than M1
objects. This is a consequence of the
UMLEvaluationOptions::EVALUATION_MODE evaluation option, which is by
default EvaluationMode::ADAPTIVE.
To solve your problem, just set the evaluation-mode of your evaluation
environment to RUNTIME_OBJECTS (meaning that your instance
specifications are treated as an M0 instance of the
InstanceSpecification metaclass taken as an M1 element of the UML
metamodel).
EvaluationEnvironment<...> env = // get from your OCL or your Query
EvaluationOptions.setOption(
env,
UMLEvaluationOptions.EVALUATION_MODE,
EvaluationMode.RUNTIME_OBJECTS);
> Set(Type) = Set{} |
> else
> result
> endif)
> Results:
> OclInvalid
> Any suggestion?
-----8<-----
Re: Navigate through a model [message #67633 is a reply to message #67591] Wed, 11 February 2009 09:04 Go to previous messageGo to next message
Hi Christian,
I figured out that the Editor uses a Ecore OCL Instance and the
InstanceSpecifcations treated as EClasses.
I don`t know why my expressions before don`t work?
But this expression solved my problem.
self.getModel().nestedPackage->any(name='Classes').member->iterate(e;
else
result
endif)
Thank you for your help and keep up the great work.
Peter
Christian W. Damus wrote:
> Hi, Peter,
> HTH,
> Christian
> Peter wrote:
>> Hi Christian,
>> set the Classifier with ": Classifier". The constraint gets the
>> possible Classifiers.
>>> C to Classes:
>>> - directly:
>> Results:
> it with:
>>> - indirectly:
> metamodel).
> env,
>> Set(Type) = Set{} |
>> else
>> result
>> endif)
>> Results:
>> OclInvalid
>> Elements.
>> Any suggestion?
> -----8<-----
Re: Navigate through a model [message #67654 is a reply to message #67633] Wed, 11 February 2009 17:15 Go to previous message
Hi, Peter,
More comments in-line, below.
Christian
Peter wrote:
> Hi Christian,
Ah. Perplexing, indeed.
> else
> result
> endif)
Great! I'm glad that's working for you. Just, if you do ever find a
spare moment to reproduce the original problem, I would be interested to
know whether there isn't some bug that should be fixed in the OCL component.
Thanks! for the vote of confidence. I appreciate it.
> Peter
>> Hi, Peter,
>> HTH,
>> Christian
>> Peter wrote:
>>> Hi Christian,
>>>> package C to Classes:
>>>> - directly:
>>> Results:
>> UML2 code generator. Is has no correspondent in OCL. But, you could
>> emulate it with:
>>>> - indirectly:
>> their evaluation in the run-time system. That is, since
>> M1 objects. This is a consequence of the
>> metamodel).
>> env,
>>> Set(Type) = Set{} |
>>> else
>>> result
>>> endif)
>>> Results:
>>> OclInvalid
>>> Elements.
>>> Any suggestion?
>> -----8<-----
Previous Topic:[Announce] MDT OCL 1.2.3RC2 is available
Next Topic:problem with OCL.validate(OCLExpression)
Current Time: Sat Nov 08 16:27:13 EST 2025
Powered by FUDForum. Page generated in 0.03436 seconds
