Home » Eclipse Projects » Eclipse Platform » Is eclipse a debug bug?
Is eclipse a debug bug? [message #66751] Sun, 08 June 2003 07:58 Go to next message
Originally posted by: song.chen.cloakware.com
I got a problem: B_$$_ucket is legal identifier for class name. Eclipse
can run it properly. But when set breakpoint inside somewhere and debug,
eclipse said:"The source of the type 'B__$$__uckets' could not be shown as
the type was not found".
I have tried Jbuilder, which can run/debug fine under exact same situation.
Does anybody get same problem? I can't change file name and have to
debug. Appreciate any help or advice from anybody?
CS
Re: Is eclipse a debug bug? [message #66790 is a reply to message #66751] Sun, 08 June 2003 10:52 Go to previous message
Originally posted by: jared-eclipse.mn.rr.com
You should file a bug report, including a reproducible test case, against
the JDT-Debug component.
- Jared
> situation.
> CS
Previous Topic:Classloader issue with Eclipse
Next Topic:[ANN] FIGlet plugin 0.1.0
Current Time: Sun Oct 19 11:56:36 EDT 2025
Powered by FUDForum. Page generated in 0.03735 seconds
