| eclipse 2.1.0 crashes on startup -> mac os 10.2.6 [message #65864] |
Fri, 06 June 2003 14:46  |
Originally posted by: french.sims.berkeley.edu
hi,
i'm having trouble starting eclipse 2.1.0 on mac os 10.2.6. when i
double click the app's icon, it bounces for awhile in the dock, and then
*poof* -- it crashes. there's no information in the system logs. i also
tried changing jre property in the info.plist file to 1.4.1, 1.4+, etc.,
but to no avail (i think eclipse came with the property set to 1.3*).
perhaps i'm missing something. i can't find documentation on this
problem, though, and i'm getting desperate! if you can point me to a
tutorial on how to properly set up eclipse on mac os X, i would be
eternally grateful.
thank you so much for any help you can offer.
salut,
--bill
| Re: eclipse 2.1.0 crashes on startup -> mac os 10.2.6 [message #68940 is a reply to message #65864] |
Tue, 10 June 2003 05:15  |
Originally posted by: Andre_Weinand.oti.com
On 6.6.2003 20:46 Uhr, in article bbqnie$m28$1@rogue.oti.com, "Bill French"
<french@sims.berkeley.edu> wrote:
> hi,
> eternally grateful.
There shouldn't be much of a setup necessary.
However, make sure that:
- you have installed the final version of Java 1.4.1 even if you are not
using it (earlier developer previews of 1.4.1 made Eclipse crash even when
running Eclipse under Java 1.3.1)
- you don't have a xerces.jar library installed in one of the standard
places. Eclipse will throw a ClassCastException.
If you still have problems, please post any Console output or the contents
of the .log file (<workspace>/.metadata/.log) here.
--andre
FUDForum. Page generated in 0.04607 seconds
